After you do that, I'll give this vehicle a bigIm in the middle of making a mount that will move it by the license plate.
I've definitely gotten plenty of use out of mine. As long as all of your connecters are in good shape and have enough silicone in them you won't fry your computers unless you completely flood the cab.
Why the snorkel? It's not like you can use it you would destroy every electronic on the vehicle if you actually tried to use it....
The tubing is under the antenna so i dident do anything with it ill put pics of it without the fender later today so u can see it
If u live in south fl its good to have one as far as electronics they have to be protected Vaseline helps a lot
