My Oven Build. | Ford Explorer - Ford Ranger Forums - Serious Explorations
My Oven Build.
Well, it's finally coming together now-
Of course, I'm talking about my long awaited professional oven build.:D
Now-first I must explain that I shouldn't even be doing this stuff. I'm disabled and make no money-but man I gotta be involved and this is about the best way I can think of. besides-it gives me something to look forward to, and that's what is important.
It has taken a long while to gather these bits-and now that I am into it deep I figure what the heck let's show it off.
Now please remember along the way-
I run out of cash often, don't dip into savings and move real slow.
A good oven needs good control
Here is Precision Instruments 1/16 din PID controller
It has fuzzy logic-heat ramping and multi zone capabilities. All with .02% accuracy
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
The PID cannot handle 220 volt switching-
so for heater element control , 2-40a SSR's
( solid state relays) with their own custom made heat sinks
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
Since the SSR's will be quite hot when switching-and also be in an enclosed panel-
I have this squirrel cage blower for cooling the "electronic control module"
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
"Safing"
Rockwool furnace and stove insulation. I have 5 bundles -32 sq ft each.
it is cut into 4" ( thickness) x24"x48" chunks.
This stuff is quite expensive-as you can imagine
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
12-
4x8' sheets of 26 gauge
I bought 3 additional sheets of 16 guage for high stress panels
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
Now
this part took quite a while to find-but was necessary.
You need a view window-door for sight and temperature checks.
During the cure cycle the part temp must be monitored. You don't want to be opening a 4x8 foot door to do this-and a "flush mount" oven door is very hard to find.
I needed one from a nicer styled camper-and finally found one.
Right after this I found an identical --in case this one breaks.
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
And now-here we are-
I have the front door framed for the view window door, which will have it's own latch and seal
Yes-that is the oven door, laying on it's side.
The oven frame is being constructed using 16 gauge metal studs ( load bearing rated) and 3/16" rivets.
I'm clamping each intersection, and drilling the holes with a "Uni Bit"
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Wow that's going to be huge!! Looks like you'll be able to powder cook some axles in there.. among other things I guess, like a hipo, should the need arise (a nice glistening yellow hipo).
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
I'm going to incorporate a removable shelf which also "cuts off" the convection flow and diverts it-
This will cut the oven size by 60 % for normal "everyday" use.
For the huge stuff I will still be prepared-
sparkyXplorer
Johnstown, Colorado
99' Limited AWD 5.0L
Getting closer to doing your first car soon....
Charlie
Wisconsin
2000 Limited
He's probably planning on doing his Mounty one body panel at a time! He's gone mad!:D
That thing looks huge!!
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
Very cool! Err, hot!!
I predict there will be some Dodge Dart parts coming your way soon;)
MONMIX
I fix dents
Moderator Emeritus
Millersville , Maryland
2000 Explorer Sport
ErickSaint
Milwaukee, WI
'94 XLT
Jon, were you building from this link? http://www.f-5performance.com/powderoven.htm
Seems I have seen the link before, and thought it was here. That link came up on a cycle forum that I lurk on. Actually that link seems to pop up all over, must be a popular project. I was just gonna try a few small parts with a harbor freight kit and a thrift store toaster oven.
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
I was-
And yes I did reference the link-only to show the framing.
however it is only good for ideas. It is so outdated the sources and prices are whacked bad. The only idea I am using from that link is the wall attachment.
This is a HUGE oven--BTW
