My photos/schematics/diagrams still available. | Page 6 | Ford Explorer - Ford Ranger Forums - Serious Explorations
Bbirge89
2005 explorer sport trac
2005 sport trac mystery bugs
Hi Steve, my name is Brandon and I am a new member. I am replacing the water pump on my 4.0L v6 sohc 2005 sport trac and was hoping you had some diagrams or any helpful info for my project. I've already run into several differences between the owners manual that came with the truck and the actual truck itself. Fuse diagrams incorrect, etc. also, I'm in the process of trying to free my fan belt but cannot seem to break the belt tensioner free by applying normal upward or downward force and am afraid to put all my muscle into because being a fairly inexperienced DIYer, I'm hesitant to be over aggressive with my only source of transportation. Thanks in advance for any help! -Brandon
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
Glad to see the "we done it" guys jumped in to help.
Bbirge89
Yeah, me too. I had already gotten the belt off and realized I hadn't broken the bolts free from the pulley so opposing force against two ratchet wrenches with 8mm bits was the easiest way to lock the pulley in position while breaking free the bolts
SportTrac-tor
Humboldt County CA
01 Sport Trac
How about a rear window motor wiring diagram? I am building a Sport Trac on Rockwells with 54" Boggers and a 6.9L Diesel. I am getting rid of all the factory wiring but want to be able to use the power windows. Need some help with why an electric window motor needs 8 wires... any help would be great.
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
Sent to your Yahoo mail you registered with.
Dragon74
Austin, Texas
2004 Ford Sport Trac
would you happen to have steps to replace (and location) of the Fuel Rail Pressure Sensor for a 2004 ST XLT?
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
Sorry but I do not have that one.
jcgrady
SE Michigan
2002 Sport Trac
Hi
Do you have a fog light wiring diagram for a 2002 Sport Trac? Or would you point me in the right direction to find one?
Thank you
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
krs_med
South carolina
2003 Explorer Sport Trac
Looking for wiring diagram for over head console 2003 sport trac. Would you happen to have one? Tanks Keith new member also and thank you for all your help!
Kjhadfield
Panama City Beach, FL
02 sport trac 4wd
Another new member. Been lurking for some time but now I haven't had any luck searching for my question so I need to ask of some help.
I have had the drivers door electrical pinch for some time now. Had payed ford, if not a hand or leg for sure a finger or 2, to "fix" the problem and it was fine for awhile…but here we are again (past their "warranty of services" period). Basically in the drivers door when closed would cause the window to not work or the speaker or the lock wouldn't engage or the window switch won't light. But if you find the sweet spot when doors opens everything has power. I already know the problem and have found that thread on the forum, which is why I tackled said project. I guess ford decided fixing it was to cut my boot, crimp wires and zip tie back together. Wouldn't you know the wire detached from the crimp. I expected it to be fixed right by soldering, asking to much I suppose.
My question is identifying certain wires, the ones that were pinched/severed. The blue wire with black strip (I believe it's 14awg), blue wire with white strip (I think is 18awg) and orange wire with green strip (18?). If anyone can point me to the right direction, I'd appreciate it and sorry if this is in the wrong thread, I figured diagrams or the like would help.
Thank you
Edit: there is a blue/black stripe wire that runs up to the driver door control switches, so maybe that's for the window controls?
easyeric
el centro ,california,usa,earth,milky way galaxy
'89 ranger 4x4
1991 ranger/explorer diagrams
hey steve, by chance do you have the 1991 truck wiring diagrams... ranger/ exporer/ the large foldouts? pdf i hope...in the middle of a 4.0 explorer engine swap into my 89 ranger. thanks easyeric.
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
Hi
Thank you
Sent
Sent
Thank you
Sent what I have
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
Eric, I have only one large foldout set of schematics for a Ranger and I think it's a 1991. But it IS the paper version. I'll be glad to loan it to you.
easyeric
'89 ranger 4x4
schematics
how would we go about that? i was able to buy a set of the large foldouts for my 89 but could use a set for a 91 too.
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
I will email you.
Get my email Eric?
easyeric
'89 ranger 4x4
just read and returned email
krs_med
South carolina
u can buy the correct pig tail from Crutchfield with diagram for les than ten dollars. That what I used on my 2003. Worked great!
keith
nanaimoguy
Nanaimo, BC
2001 Explorer Sport Trac
Looking for Igignation system diagram for 01 ford explorer sport trac
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
