gavin
- September 27, 2002
- Anchorage, Alaska
- '97 Explorer XLT AWD 5.0L
Glacier991 said:"Thus finer elements (spray or fog) require less energy (heat) in order to change their state of matter (solids to liquids, liquids to gas). "
I respectfully disagree. A given quantity of a liquid will require the same amount of energy to convert it's state from one phase state to another (liquid to gaseous), regardless of droplet size. The fog does it faster because more surface area in the frying pan is used. Actual heat energy (latent heat of vaporization to be exact) used is the same. NOW, Whether this affects the point you are making is another matter. Just for clarification. (damn AC background)
kinda like takin an ice cube, and puttin it in a cup of warm water.. it takes so long to melt. Now take that same ice cube, break it up into smaller pieces, and it melts quicker. Same thing with say chocolate in your mouth.. a whole bar will take so long to melt, but if you break it up it takes less time to melt. It's not that it's taking less energy, but as Glacier said, the same amount of heat is being spread over a larger surface area, melting the material quicker.
