RenDnB
- November 29, 2017
- 2006 Explorer Eddie Bauer
Hello Everyone,
Figured I would share my spark plug change story since I used this forum for advising. My father passed away recently. Shortly before he did, he gave me his 2006 Eddie Bauer 4.6L Explorer. Always loved that thing and really glad I have it. Its in decent shape, especially after a bunch of rebuilds he had done with it (instead of trading it in, he plunked down a few thousand dollars to have its tranny replaced, and parts of the engine repaired when it threw a belt).
Anyway, its started ticking and running really rough recently. The CEL came on and I had Advanced Auto check the codes for me. The number 1 spark plug was misfiring; which I thought was odd as I knew he had them changed not long ago. So figured, might as well change all the spark plugs. I referred to this forum for the procedure and things to look out for while I'm doing the change.
Reading all of the horror stories of broken plugs freaked me out a bit. Once I had the money, I bought all the plugs and everything I would need (including the odd sized plug socket which was a 9/16th). I walked through what I was going to do, but couldn't afford the Lisle Spark Plug Removal tool. I was still freaked out about breaking a plug, as my wife told me I was talking about breaking a plug in my sleep haha! My dad did have a mechanic, but given some of the issues I've been having, I was questioning if he did the job.
Anyway, this past Saturday I did the job and happy to report that everything went well. No broken plugs! All plugs came out nicely, with the exception of a few that squeaked and creaked out. However, I found the problem with the number 1 spark plug. It wasn't tightened in at all, and the electrode in the plug actually shot out of the spark plug and welded itself to the plug. Either way, his mechanic did replace them.
After I put all the plugs in and tightened them down to 25 foot pounds per the Haynes manual(I did not use Anti-Seize as a lot of posts I read said not to use it or risk over-tightening), fired up the truck and it sounded smooth and brand new! Also, that ticking sound thats been driving me crazy for the last few months I've owned the truck went away.
Just want to list what I did in case someone needs it:
- Did this from a cold engine. I did not heat them up.
- Had to buy a 9/16 spark plug socket. Got a cool one from Advanced Auto that was magnetic.
- Used an air compressor to clean out the holes after I pulled the boots off
- Used PB Blaster to loosen the threads. Sprayed around all the plugs and let it sit for 15 minutes
- I used a long 1/2 inch torque wrench to remove. Set it to 30 foot pounds so I wouldn't "force" a plug removal. Some were a little over tightened, but I was able to get them all out.
- Wiped out each spark plug hole and then put the new Autolite HT1's in
- Torqued them down, put it all back together and fired it up (used dielectric grease in the boots)
