Mysterious 5r55e noises, wont shift | Ford Explorer Forums - Serious Explorations
swptln71
Hi gents, I've got an uhappy 98' Explorer 4x4 4.0 with the 5r55e trans. I've searched thoroughly but haven't found my answers, so here it goes. The truck has 185xxx. It will make a rapid clanking noise when it is put into any gear. It sounds like a baseball card hitting the spokes on a bycle. It sounds like something is clanking as it rotates inside the trans. The truck will not engage in any gear or any setting on the t-case selector, but P will engage and the truck will act as if its in neutral when any other gear is activated. The trans was replaced today with a junkyard trans and torque converter that were both supposedly tested. The old t-case was reused. I didn't see any flashing lights on the dash, i.e. O/D light. Could this be a bad t-case? Another bad trans? I'm stumped and very much appreciate any help. Thanks
If 2 trans did the same thing, then it is probably the transfer case.
