jglover
- March 6, 2015
- Atlanta, GA
- 1994 Mazda Navajo LX
Been fighting with the bouncing voltage issue on my stock '94 Navajo. Replaced voltage regulator and brushes on existing alternator, then replaced whole alternator with a new one and initially thought resolved, but the issue returned. Looked for loose/bad connections and couldn't find anything visually, but voltage seems to stabilize when cold or after I'd confirmed all fuses and relays in the power distribution box were seated. I was thinking maybe a relay was to blame, and considering replacing a couple to test.
This week, after a two-hour drive where voltage was steady at normal charging level, started up 10 minutes later and nothing but battery voltage. I check again around the box and behind it, between it and the blower motor, I find a disconnected multi-wire plug that I connect find the mate for. Nothing visible within the length of the wires on it. Does anyone know what this connector goes to and should be plugged into?
Thanks in advance.
Thanks in advance.
