JohnJ
- April 10, 2008
- Brick, NJ
- '92 Puttied
On my 92 Exploder 4x4:
During moderate or hard braking I get a creaking noise (moving forward or backwards) which is accompanied by a popping vibration felt in the floor.
Radius arm bushings are new but the bracket on the right hand side needs to be replaced due to wear. Ball joints on the left side are new. Right side lower has some play. Brake pads are approx new and rotors are freshly turned, and in spec for thickness. Front wheel bearings are in good condition. Calipers are probably original but appear to be in acceptable condition (but they will soon be replaced as they are just too old for me to have faith in the seals) and lubed with moly grease. Coil buckets are solid. Left side coil spring is sagged a bit.
The noise was present during any braking including very light braking when the left side ball joints had noticable play. After replacement of those joints the noise disappeared but after about 500 miles it has returned. The noise now is not as loud and the popping vibration is milder as well.
Anyone want to make any guesses?
