Narrowing a full width axle | Ford Explorer - Ford Ranger Forums - Serious Explorations
JoshC
Only rolled it once honey
Culloden, WV
97 4d OHV
I just bought a FW D44 from a 78 F150. Now, i know nothing about the 44s and nothing about narrowing axles. If i narrow this thing down, am i going to have take it down to it will accept EB shafts or do you just narrow the FW shafts also?
And no i'm not going to be doing this, i'll have someone do it, i'm just asking cause i don't have any idea. I notice alot of people are keeping them FW, but i don't think that is my style. I like to have it stock width, or close to it.
Who all has narrowed a 44 to fit their explorer?
98 sport
Lancaster, New York
98 Sport
Hey check out the length of an Early Bronco (66-77) D44. Its no high pinion but the inner shaft lenghts might be just what your looking for, and their off the shelf too.
CodePoet
Indianapolis, Indiana
1993 XLT
narrowing a 78-79 isn't that complicated...here's a link to the process http://www.torc4x4.com/techpage.html
As far as running it full width it has nothing to do with style for me...I want the extra stability. It may be alittle hard on extremely tight trails...but that's what using your sliders as piviot points are for haha (actually i dont' want to do this). I don't plan on lifting my truck much...if i'm lucky it'll only be about 6"s over stock :)
bmxking5
Monroe, GA
'93 Sport & '96 XLT
Maybe after that roll over, you SHOULD be considering full width for more stability. :p
There are varying measurements across the net, but you'll want it narrowed to fit an Early Bronco (66-77) passenger side inner shaft, since you'll be cutting down the passenger side. I've seen everything from 5" to 6.5" as being what it needs to be cut to on that side in order to fit the EB shaft. I believe Daemon cut his down 5 and 3/8" or something like that.
4.0L_4X4_Rob
Edmonton, Alberta
2000 Sport 4X4 5spd
what are you going to do with the dana 30?
JoshC
Culloden, WV
97 4d OHV
I'll end up selling the D30.
Thanks for the info guys. I had thought about keeping it full width for the stability, but then i've gotta get a rear axle too. Not a bid deal since i can sell the 8.8 to a jeeper for a good chunk of change, especially with a 4.56s and locker.
CodePoet
1993 XLT
You could also keep the internals of the 8.8 you have now and put it in a full width 8.8 from a newer f150 :)
JoshC
Culloden, WV
97 4d OHV
Already in the works. I think i've located a free 8.8 so i'm trying.
Thanks for the links fellas.
CodePoet
1993 XLT
GOOD!
Assuming you have the stock drums on your current rear end you'll gain discs in the process :D
JoshC
Culloden, WV
97 4d OHV
Already have discs.
The guy i'm getting it from said it doesn't have the R&P or carrier, so i'm using mine, but will my disc brake pieces work on it? He wasn't sure if the backing plate was the same or not. It's from an early 90s F150.
CodePoet
1993 XLT
not sure. I know that my 05 f150 has a 6 lug pattern though instead of a 5 like the explorer's do though.
JoshC
Culloden, WV
97 4d OHV
Even the older 5 lugs are still different. 5 on 5.5 instead of our 5 on 4.5.
JoshC
Culloden, WV
97 4d OHV
Exactly :thumbsup:
