vfral1
- February 8, 2011
- Cumming, GA
- '11 LTD Golden Bronze
2011 LTD factory NAV v3.2.2 A3 sd card...
After a voice command search for an address the bottom half of the NAV screen would not refresh with the top half, it just remained a gray block. I performed a master reset and to my dismay it did not correct. So as a last resort I removed the sd card and reinserted it. This caused the screen to refresh and correct the problem. Later in the day the same issue occurred while manually entering a destination. Again an sd card reseat corrected the problem. It has worked fine since, but its only been a day.
In general I have not had any problems with the v3.2.2 system that has been in operation since last march. So I'm wondering if this is a hardware rather than software based problem...could the apim be going bad?
Has anyone else had this same error?
