littlesmail
- June 11, 2011
- el centro
- 1991 mazda navajo
here is my 1991 mazda navajo that i am building, i started over a year ago with a cage, and after i was done with that i decided i wanted to link it, so here is a timline of pictures.. let me know what you think!
before i started it had all stock interior with a simple cage just welded to the cab.
front end is custom ttb with custom radius arms and coil sprung with a dual shock set up
decided to start all over in the interior and do a good solid cage to the frame
main hoop
the halo
dash bars.. went through the ac box in order to keep ac
finished cage and fuel filler/ spare mount..
for rear tail lights
seat mount..
built a removable light bar
here are a few finished interior shots.
decided to pull it back into the shop and shorten the radius arms up and put them on heims, and 4 link it with a 9 inch rear end.
radius arms with stock bushings
modifiing them for heims
and the finished raduis arm/ 4link mounts, and the start of the 4 link.
crossmember in between the mounts
upper 4 link mounts
let me know what you think so far!
main hoop
the halo
seat mount..
upper 4 link mounts
