Neat things you have found out
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Rapid Red
2020 ST Street Pack
I like that can have all three vent types (windshield, directly at you, directly on feet) going at once. In my 2014, 2016, and 2018 explorer sports, it would only let you choose two out of three to be running, which I could never understand.
Had a weird situation when stopping for a signal tonight. I pulled up close to the car in front of me, so the car behind me could squeeze by into a turn lane. My hands were directly on the steering wheel. And my highbeams turned on! Not sure what caused that but the person in front of me probably wondered why I was giving them the highbeams! Thank goodness I was able to turn them off right away.
“Christine” has been behaving for a solid 3 weeks now but may be spoiling for some more mischief.....
Forddealz
NY
2020 Ford Explorer ST
I have to double check on that one. I pressed that 3 way climate control button but then on the screen I could only select one of them before they started. I have to double check. i was able to get one at a time but not all vents blowing all at once.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
.......Had a weird situation when stopping for a signal tonight. I pulled up close to the car in front of me, so the car behind me could squeeze by into a turn lane. My hands were directly on the steering wheel. And my highbeams turned on! Not sure what caused that but the person in front of me probably wondered why I was giving them the highbeams! Thank goodness I was able to turn them off right away.
I'm guessing your headlights were already on when that happened? If so, you may have been too close to the vehicle in front in order the sensor to pick up the taillights.
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
@peterk9 "Neat things"........
Took me a LOOONG time to find this out, and it was by accident when scrounging around once under a Ford F-series 4X4 I noticed the front differential pinion gear was ON TOP of the pumpkin center section. IOW, the pumpkin was upside down!
I already knew about gear teeth and such, and that ring gear teeth are much stronger in one direction than the other.
Looking at the lowest few teeth above, the tooth profile difference is easily seen: the right hand face rises nearly vertically from the bottom of the tooth, while the left hand face rises upwards at an obvious angle which is sloped. The vertical faces are termed "DRIVE" faces, the others "COAST" faces. This means the drive faces transmit the forces to move the vehicle in the forward direction, "seeing" the highest forces, while the coast forces transmit only the force needed to keep the driveline turning when the throttle is closed.
Thus, drive faces in the REAR AXLE are really driving faces. But, the 4X4 design has the entire axle, in the front, turned around, causing the front gearset to be reversed also, and the forces to move the vehicle FORWARD are applied to the usually COAST faces.
So what? .....Gear teeth always try to "spread" themselves apart. The vertical DRIVE faces produce almost no spreading. Forces applied to the COAST faces force the gears apart. Such was a fact of life in early 4X4s, on up through the 1960s, and perhaps '70s. At that point, after many front axle failures, manufacturers began the unusual process of installing the front axles, UPSIDE DOWN, to make the old COAST faces again do "coasting duty". This placed the pinion and it's bearings higher up, clean out of the "pool" of lubricant they sat in in the REAR axles. Why they took the final step.......I am not sure. Because it confused many who did not understand all this tooth bullshit, or the final "fix" used:
They began cutting ring and pinion gearsets as "reverse rotation", to be used in plain old rear pumpkins for use "up front"!
Rapid Red
2020 ST Street Pack
That makes a lot of sense - I forgot about the automatic high beam at night feature. I may get have to look at disabling that - or just don’t get too close to the car in front of me!
KTrabue
CO
2020 Explorer ST
I don’t seem to have the two small panels to cover the side rear cargo areas that I see in your photo. Are they stored somewhere in the vehicle and I just haven’t found them? I have the main board as well as the small rubber mat for the center area.
The small panels can fit into the slots vertically and be pulled out and laid flat instead.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
I'll take my heated blades for $140 that heat up instantly. Domt know why it has taken so long for this. Aftermarket has had this for many years and they work fantasticly.
  • Like
Reactions: imp
peterk9
Staff member
Moderator
Callsign
VE3
I think the difference is that the washer fluid is also heated. The first time I tried the front washers, I wasn't sure where the spray was coming from. The video explains that it comes from the wipers themselves instead of the usual nozzles. I'll have to see how this setup works this Winter.
  • Like
Reactions: imp
TBill
Prescott, AZ
2020 Explorer Platinum
Navigation turns show in the digital dash screen:)
TBill
peterk9
Staff member
Moderator
Callsign
VE3
I just discovered that when the headlights on my Aviator are ON, all 4 are powered, and no, they are not on high beam.
metroplex
Location
Detroit, MI
Detroit, MI
2018 Ford Explorer XLT
Chrysler had the heated wiper fluid almost 20 years ago. Not sure if they had heating elements at the blades, but I am sure the Germans already had that. US automakers are still behind the curve with washers for the headlights that are mandated by UNECE countries.
EJH220
Bennington, NE
2020 Explorer ST
That's actually pretty cool. I'll have to check my wife's out.
RJT895
2020 Explorer Hybrid AWD
Level of outside noise control. We drove by a street performer playing a violin and couldn't hear anything, even with the radio off.
