I'm having my stock gt40 stage 3 ported..will outflow ANY intake on the planet by the way and appear stock. ..
But I'll be using a 70mm TB off of a foxbody.. how are you guys going about wiring these up? I just got into the explorer stuff for my ranger.. but some of the stuff is foxbody parts..
2000 explorer computer. Sorry about that. What I dont know is if the foxbody MAF sensor will work on my 2000 explorer setup. I need about a 76mm or 80mm maf sensor matched to some 24 lb injectors.2001 Ford does indeed have the incoming air temperature sensor inside the MAS air flow sensor
This is the IAT temp sensor for the engines computer
There are 5 wire MAS sensors up until 98 and the IAT sensor is in the intake tube between MAS and throttle body
There are 7 wire mas after 98, the two additional wires are for the IAT sensor which is now integral to the MAS sensor housing
The ambient air temp sensor posted in the pictures above are for the overhead console displaying the outside temp and has nothing to do with engine functions - it does NOT report ambient temp to the pcm as the 5.0 Explorer computer only cares about the air coming into the engine
Nice gt40 and gt40p heads can flow very well when ported and polished.
Wiring what up? Are you running an explorer computer or a mustang computer
What year computer?
Wiring up the 70mm MAS? your post is not clear
I am having it dyno tuned..for sure. Compression should be around 9.5:1 . Having the rear 02's deleted,egr, auto trans.functions and the evap...(track duty🕶) Anderson N412 cam, 1.6 roller rockers, 24 pound injectors.It sounds like you are in need of a tuner. The MAF flow curve can be input for any MAF and you can also change injector sizes. In doing so that allows the EEC to know what the MAF is reading and the EEC sends the appropriate fuel pulse making for an accurate tune.
Some cams don't play well with EEC's. What all are you tuning for, what's the build? You gave heads, no cam, compression ratio, etc. Anything else being done to add power?
I have found ebay and the mustang sites good for used and new parts for these engines.
That’s a pretty bold statement. I’m sure many aftermarket intakes would flow better.By the way... since I'm here asking.. I'm having my stock gt40 stage 3 ported..will outflow ANY intake on the planet by the way and appear stock. ..
Gaurantee it will out flow any aftermarket intake on the planet..as far as street/race. Edelbrock, Trickflow, all those.That’s a pretty bold statement. I’m sure many aftermarket intakes would flow better.
What’s your target HP and RPM?
Ok..I'll check with the tuner. ThanksYour 2000 Explorer computer is OBDII and will work with about any MAF that you have a flow curve for that you can input into a tuner or that the tuner will already accept, like being able to choose it from a pick list. A Mustang MAF will work. I am supercharging a 2000 utilizing a 90mm Lightning MAF with 42lb injectors. The 42's are a little big, but I may add more boost and goodies down the line..................
Your tuner, device and/or person will likely determine what MAF you can run. The tuner must have the MAF flow curve or you have to be able to build it.
