Need a good rebuilt transmission in the high desert
tundrawolf
Hello,
I need to swap out the transmission and torque converter in a 2005 Ford Explorer 4x4, V-8, 4 door non sport track. Can anyone recommend anyone to sell me the trans and new/rebuilt torque converter?
94Eddie Need transmission rebuilt (5R55W) and advice Transmissions & Transfer Cases 2
Tarpman need advice, factory rebuilt or rebuild existing tranny? Transmissions & Transfer Cases 5
S Need Rebuilt Torque Converter? Transmissions & Transfer Cases 3
B had trans rebuilt, need some info please! Transmissions & Transfer Cases 5
D New member... In need of transmission help... Transmissions & Transfer Cases 1
9 5R55E - L keepers in valve body during rebuild. Need advised please! Transmissions & Transfer Cases 1
W 4r55e input shaft jammed, need help removing Transmissions & Transfer Cases 11
J 2005 explorer axle 45 need traction...swap diff to torsen style? Transmissions & Transfer Cases 6
P need to replace or rebuild my 5r55w... what to do? Transmissions & Transfer Cases 3
R Need info on 99 Explorer transmission Transmissions & Transfer Cases 2
R Need info on 99 Explorer transmission Transmissions & Transfer Cases 0
Fredness 5R55E possible issues found - Need thoughts/peer review Transmissions & Transfer Cases 4
9 Need specs Transmissions & Transfer Cases 0
C need info on 04 ranger 4wd system. Transmissions & Transfer Cases 2
L Need help finding a transmission for 4 l to fix my 92 ranger Transmissions & Transfer Cases 2
bigred4x4 Need help with tranny cooler Transmissions & Transfer Cases 0
B Need Advice - No Reverse - 1999 4.0L SOHC Transmissions & Transfer Cases 2
D Help! In desperate need of a transmission in AZ Transmissions & Transfer Cases 3
S Tricking the PCM... need info Transmissions & Transfer Cases 2
X Need help with this terrible vibration..transfer case? Rear? Transmissions & Transfer Cases 3
S 04 tranny issue need advice Transmissions & Transfer Cases 0
X need a4ld parts! Transmissions & Transfer Cases 5
T need a little help Ford Ranger A4LD Automatic Transmission o/d Transmissions & Transfer Cases 2
W Need Advice with A4LD Boost Valve Transmissions & Transfer Cases 4
B Need an atf cooler?? Transmissions & Transfer Cases 2
B Explorer transmission, slipping returned after new VB?? Need ideas please Transmissions & Transfer Cases 4
J 1999 explorer sport 4x4 speed sensor - Need photo Transmissions & Transfer Cases 0
J Need help deciding gear ratio Transmissions & Transfer Cases 5
1 06 b2300 transmission rebuild 5r44e!! need specs!! Transmissions & Transfer Cases 3
B Need to know what transmission will work Transmissions & Transfer Cases 3
B need help asap please...Delayed reverse & 1-2 flare Transmissions & Transfer Cases 15
P I need help with bleeding my clutch Transmissions & Transfer Cases 5
Y Need a little advise/04 Explorer Reverse Servo Screen Has Hole in it Transmissions & Transfer Cases 1
S Transmission problem need help ASAP Transmissions & Transfer Cases 2
S 5R55S in need of rebuild Transmissions & Transfer Cases 4
T 5r55e no 2-3 shift need help Transmissions & Transfer Cases 8
9 need help with trans parts Transmissions & Transfer Cases 2
9 need help with trans parts Transmissions & Transfer Cases 0
F Do you really need the dust shield? Transmissions & Transfer Cases 0
Z O/D Light Flashing.. Need Help! Transmissions & Transfer Cases 10
R Need a Trans Shop Recommendation- Portland Transmissions & Transfer Cases 1
M A4LD "hiccups", need help! Transmissions & Transfer Cases 12
R Replacing my 97 5r55e, NEED HELP! Transmissions & Transfer Cases 0
C Need to make sure I'm ordering correct parts for m5r1 rebuild Transmissions & Transfer Cases 1
L 4406 Need Help Transmissions & Transfer Cases 6
C need help narrowing down my problem Transmissions & Transfer Cases 9
C Need to know how to re-build a 1354M t-case Transmissions & Transfer Cases 1
L Need to install a vss Transmissions & Transfer Cases 2
C HELP. I need to grease a non-greasable u-joint. OK to drill cap? Transmissions & Transfer Cases 16
1 Need more traction stat! Transmissions & Transfer Cases 18
Similar threads
