Yes, and no... If it were me, I'd go with two 8's in that somewhat limited airspace. You get more surface area than a single 10, and almost as much as a single 12. Heck, if you choose the right ones and had enough amp, you could put three 8's in that space which is almost as much cone area as a 15! My personal preference is either an Infinity Reference 8 or JBL GTO 8. They are virtually twins and model almost identically. Sealed, your looking at .33 ft^3 each; ported is ~.66 ft^3 but a crazy long port depending on the tuning - 3" tube would a 36" long port to tune @ 29 hz with and f3 @ 26 hz
If you shift the tuning up to around 33 hz the vent is only 23.79". You could prolly go even higher on the tuning since cabin gain will boost the low end, so you may even get two 8's in a ported enclosure. If you can squeeze an extra .1 ft^3 somewhere, a .55 ft^3 ported enclosure tuned at 36 hz needs two 1.5" diameter ports that are 12" long. That is more manageble. Your f3 is still 31 hz, so you'd be well in to the 20's with cabin gain. A slot port would be ideal in any of the above vented enclosures, but you'd need to recalculate the length. I have both setups, one in each car; one ported, one sealed, one JBL, one Infinity. They are both amazing little subs, both for sound clarity and low end. The ported enclosure obviously has the advantage deep down low - it's tuned @27 hz in a .75 ft^3 enclosure and really goes down deep. The sealed JBL is nice and tight, and with a LITTLE bass boost it digs down to 30 hz with cabin can, no issue. Just put a decent amount of polyfill in the enclosure.
The other option I would go for would be a single 10" sub - I'd go with an Infinity Kappa 10" in a sealed enclosure. 1.0 ft^3 gives you a QTC of .8, which is quite good and just a little on the boom side. Lightly stuffed. Just about the best sounding sub ever, IMO. Kicks like a mule, smooth as glass. Can handle a good amount of power, as can it's small brethren.
I'd pass on a single 12" - ideally most 12's need at least 1.25 - 2.0 ft^3 to perform well. You'd be missing out on the low end - mainly anything below 35 hz. And it would be way to punchy (annoyingly so, no awesomely so). Just my two cents.
