brazzle
- December 16, 2007
- Tooele, UT
- '02 Eddie Bauer
Hi all,
I know very little about cars compared to you guys, so I have come to you for help. Let me give you some background info:
About two months ago, it seems like out of nowhere my 2002 Explorer V6 4.0L wouldn't start. There was enough power to run the headlights and all internal lights, but when trying to start it all I would get was a very rapid flickering until I released the key. After cleaning the rather corroded contacts and charging for 10 minutes it ran fine. We checked the charging meter and it was right in the middle and I never noticed it drop at all, so we assumed it wasn't the alternator.
Well, two days ago while getting my oil changed, the technicians ran into the same problem and had to jump and charge it. They noted on their sheet that they believed I had a bad battery.
Today (two days later), I tried to start it after not having driven it since the oil change and I had the same rapid flickering. I assumed I needed to get a new battery so I jumped it and took it over to Autozone. The guy pulled out his machine and set forth on testing the battery while my Ex was off. He said it fell from 12V to 8V and that he believed I had a bad cell in the battery; however, the machine read "Charge and Re-Test" so he had me start it up while he tested it some more. After asking me to hold the RPMs at 2K there appeared to be a bit of flickering and I caught a glimpse of my charging meter rise from Medium-Low to Medium. I wondered if that could be a result of the machine since I had never had such a thing occur before. After that he told me the battery was fine but it seemed like my alternator was bad.
Ouch. Thats not good for someone like me who can't change it himself.
My question is, except for that one fleeting moment, I have never noticed my charge be low at all and while driving home I ran a system check and it said the charging system was "OK". Is it possible the Autozone guy/machine were wrong and it really is a bad battery like he originally supposed?
I really don't want to have to replace my alternator, but above all I don't want to waste money on something I don't need.
