66427
- October 18, 2006
- Clarksville, TN for now...or forever
- 01 EB
First...I tried the search function a couple times and could not find an answer, so, as always all help is appreciated.
So I took the Explorer out last week and the brakes seem to be working fine under normal use. Firm pedal, normal stopping distances, no pulsing, pulling, no sponginess or anything out of the ordinary. I was coming up to a redlight where the 1 lane splits to a left turn, straight and a right turn. I was going right as was the driver in front of me. The light turned yellow and he slammed on his brakes. I was already braking and just pushed harder. The pedal went straight to the floor with just a bit more stopping force. Thank god I had a large gap behind him. After the light turns green, brakes are fine. They just will not "Panic stop".
So I am thinking master cylinder...maybe?
There are no leaks and the reservoir is full, could the seals be shot?
Or rubber lines to the calipers ballooning out? Does anyone make braided lines for these?
So, if I change the master cylinder, I know how the bench bleed it, but there will invariably be a small bubble or two introduced into the lines as the swap is performed, is there a simple way to bleed this back to the master cylinder? Or do I have to pump and dump through all 4 calipers?
Again, all hints suggestions and ideas are appreciated.
