3xowner
- March 13, 2016
- Western US
- '00 Explorer EB 4SOHC RWD
2000 Explorer Eddie Bauer 4.0 SOHC RWD only with EATC (no rear HVAC system).
So I had my blend door actuator go bad... Was getting thumping noise and then intermittent issues on vent temp output. codes 24/25 when I ran the diagnostic test.
I took out the actuator and found that 2 splines were broken off and laying in the grease for the middle small gear.
Sticker on the actuator had the number, f87h19e616ab, which my local ford dealer parts guy said was a engineering number and not the part number. So with my SUVs info he said the actuator part number is YL5z19e616aa (YH-1767) and it is a white plastic casing vs the old being black.
I plugged it in and nothing... no movement from the new motorcraft actuator (i.e. post did not rotate during any temp setting change). ran the diagnostic again and got the common actuator short codes 24/25 and the solar sensor 52. I am ignoring 52 for now as it never came back up, but I did kinda give it a tap for good luck
Did things like cleared the codes in the EATC, disconnected battery positive cable. Still nothing from the new actuator and just the same 24/25 codes. Volt meter shows 5 volts on pin 6 when I ground it to metal bracket near air box while I am running the MAX AC.
I put the old, original unit back together, plugged it in and tested it with temp setting changes and the post rotated. I still got code 24 here I think. However the point is the old one is still "working" on demand.
I don't want to open up the new part casing from the dealer. Can someone tell me if this is the correct part??? I know be reading, many people have changed this and got dorman parts wrong / right... finally got dealer parts and things worked, etc.
Upon web searching, I am seeing info that this part, YL5z19e616aa (YH-1767), is for the manual temp controls.
Can some please verify what exact motorcraft part they got ???
