Need Help!!!!!! Auto Headlamps | Ford Explorer Forums - Serious Explorations
usranger80
Augusta, GA
2011 Explorer Base
Need a little help. I went through all the steps to add the auto headlamp feature to my 11' Ex. Bought the sunload sensor and pig tail, added the headlight switch with the auto headlamp position, wired the sensor up to pin #30 on the Body control module and grounded, however it does not appear that that circuit is hot, all the fuses are good and connections/splices are solid but the circuit is not getting power from the BCM as far as I can tell. I don't know what else to do, not sure if this is something that I have to have programmed into the BCM by the dealer, if ANYONE has some knowledge on this please help me out. However, if anyone is wondering how to get DRL's on an 11' Ex, that seems to be what I have a accomplished, setting the switch to the auto position turn the lights on at start, and they go off after about 30 secs when the vehicle is turned off, I guess I could be happy with that but I would really like the switch and sensor to function properly. PLEASE HELP!
