tmurr
- May 2, 2012
- 1996 Explorer XLT
I'm trying to diagnose a clunking noise in my 96 Explorer that seems to be coming from the front, or possibly under the drivers side. It typically occurs at slow speeds, while leaving a parking space. When it occurs, it is a consistent clunk that sounds like it happens with each wheel revolution.
If I turn the switch on the dash from 2WD to 4WD Auto, the clunking noise stops. If I switch it back to 2WD, the clunking returns. Eventually, it will go away. Is this a transfer case issue?
I recently replaced the rear tires only. Front tires are worn, but still have decent tread remaining. Could this be a cause?
Thanks,
Tim
1996 Explorer XLT
Control Trac 4WD
(switch on dash: 2WD, 4WD Auto, 4WD Low)
Thanks,
Tim
1996 Explorer XLT
Control Trac 4WD
