Muddybuddy
- June 12, 2009
- Fairfax, VA
- '99 XLT 5.0
Hi all, been a long time, but a good friend of mine has an ‘02 sport trac that he just bought and is trying to get it back on the road. The truck starts making a howling sound at about 5mph and gets louder as you accelerate. Does it in drive, coasting in neutral, and in reverse. However we noticed the sound stops when turning sharp left. the sound does not change when turning right. We checked the front diff, has plenty of fluid. Tires are pretty new (less than 5k miles), doesnt sound like tire noise.
-we removed the front driveshaft, no change. (Kept driveshaft off for all subsequent part changes)
-Replaced left wheel bearing, no noticeable change.
-Replaced lower ball joints (both sides), no change
-Replaced left CV shaft, no change.
At a loss right now. What are we missing? Where to go from here? Was thinking diff (bearings) but the fact that it goes away when turning left makes me think its not diff related.
was thinking about removing front diff all together. If we remove cv shafts and pull front diff, can the truck be driven? Obviously will only be 2wd, but he needs to get the truck back on the road asap.
any suggestions?
any suggestions?
