Need Help Finding a First Gen V8 Swap Thread??
9194 Sportman
Nova Scotia, Canada
1994 Explorer Sport
Hello friends,
I am searching for a V8 Swap thread on this forum from about 8 years ago.
It was a white 4-door, 2-wheel-drive Explorer that was lowered, had the 2nd Gen Explorer firewall installed, had big brakes installed and was thoroughly detailed thread.
I cannot find the thread and I forgot the forum member who built that Explorer???
Can anyone help me find this?
Thank you, Pete
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Was it a 91, 92 93 or 94? do you remember? Might help with search terms
What info do you need from that thread? Maybe we can answer it without actually finding the thread
  • Like
Reactions: imp
9194 Sportman
Nova Scotia, Canada
1994 Explorer Sport
Thanks 410Fortune,
I wanted to review that thread again in its entirety as the details of each of the build sequences were done quite well.
I know it was NOT a 1994 Explorer so you have 91, 92, 93 Explorer to consider.
Again, it was a 4-door, 2WD Explorer with a 5.0L, automatic, big front disc brake swap, lowered, and such???
I wish I could recall the member?
Thank you for trying to assist...
Pete
T Need help finding a 6" lift Modified 1991-1994 Explorers 2
T Need help finding a replacement... Modified 1991-1994 Explorers 3
D need help finding shocks Modified 1991-1994 Explorers 8
T need help finding alignment cam part # Modified 1991-1994 Explorers 4
J need help finding a bumper Modified 1991-1994 Explorers 3
M Need help finding gears!! Modified 1991-1994 Explorers 12
R wrecked my '92 off-road rig's body, need some technical help Modified 1991-1994 Explorers 32
Z Need help with 4x4 issue Modified 1991-1994 Explorers 10
M Need some help and input! Modified 1991-1994 Explorers 3
F Need help, 4x4 control module rewiring Modified 1991-1994 Explorers 1
C warrior shackle install bolt snapped, need bushing, help Modified 1991-1994 Explorers 5
B Overwhelmed with wheel options, need help! Modified 1991-1994 Explorers 13
R Need help getting cruise control to work after deleting abs Modified 1991-1994 Explorers 4
V need some help please Modified 1991-1994 Explorers 6
K Need help deciding what length shock to buy Modified 1991-1994 Explorers 6
L.A.X Need to install shackles and coil spacers...help Modified 1991-1994 Explorers 4
B i need window help Modified 1991-1994 Explorers 2
N Need help with a bolt. Modified 1991-1994 Explorers 2
H I need wheel help Modified 1991-1994 Explorers 2
1 budget build in need of help Modified 1991-1994 Explorers 2
F Need help getting a bit more power Modified 1991-1994 Explorers 4
J Noob here Need help with my 2wd Modified 1991-1994 Explorers 1
J need help with the a clutch pedal Modified 1991-1994 Explorers 2
G need help with shocks Modified 1991-1994 Explorers 1
D 1994 ford ranger 5.0 4x4 NEED HELP!! Modified 1991-1994 Explorers 0
E Need help re-installing front diff Modified 1991-1994 Explorers 3
B BII Trans In my 91 Navajo , Need B II Wiring help ! Modified 1991-1994 Explorers 12
A Dear Lord, I need help Modified 1991-1994 Explorers 13
R Need help with seats please Modified 1991-1994 Explorers 1
D need help with motor Modified 1991-1994 Explorers 4
D dual battery kit, need help Modified 1991-1994 Explorers 3
R Help in need of a 8.8 limitedslip carrier Modified 1991-1994 Explorers 8
T Need help with Aux lights!!! Modified 1991-1994 Explorers 1
M Need some help! A double clunk and a bad vibe? No Low Beams, Back Door Locked shut! Modified 1991-1994 Explorers 1
T probably already been answered but need help ASAP Modified 1991-1994 Explorers 2
T relocate air intake??? need help. Modified 1991-1994 Explorers 24
69Explorer69 Need A Little Help Modified 1991-1994 Explorers 0
P 1991 explorer slight front lift need help Modified 1991-1994 Explorers 59
Ageman Need help with transfer case question Modified 1991-1994 Explorers 0
A Ahhh need help ! Modified 1991-1994 Explorers 1
A 91 explorer 4wd ..need lift help please Modified 1991-1994 Explorers 9
T Need help with 3in body lift on first gen explorer xlt Modified 1991-1994 Explorers 4
M i need some SAS help... Modified 1991-1994 Explorers 2
janderson4010 need some help from the 4.0 experts Modified 1991-1994 Explorers 1
T Replacing shocks?....need some help/options... Modified 1991-1994 Explorers 3
E Need help lifting a 2wd Explorer Sport Modified 1991-1994 Explorers 4
H Need some help Modified 1991-1994 Explorers 24
K new truck need help! Modified 1991-1994 Explorers 5
C Need electrical help on 94 ex Modified 1991-1994 Explorers 3
69Explorer69 NEed Help on Intakes Modified 1991-1994 Explorers 14
Similar threads
