Need help finding capacitors | Ford Explorer - Ford Ranger Forums - Serious Explorations
Have a tire balancer I've been using forever and it's taken a dump on me. Pretty sure it needs a capacitor as it was working fine and when it went to start up it just buzzes and slowly turns. There are 2 capacitors inside the unit and they are stud mount with 2 terminals each. Can anyone help me find a place in the US I can order them from?
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Close ups
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
First, try local electrical parts centers, appliance supply etc.
You might then contact a local motor rebuilding place, HVAC parts service.
Unfortunately I exhausted all at the above, and eBay. Digikey was no help and I had to purchase a new motor for my 5hp compressor.
You need a 10 microfarad 450v
And a 20 microfarad 450 v
Might try Amazon and eBay,
Search 10uf 450v,. I did see 20uf 450 v available. Values are more important than physical size
Pete Deering
New England
1995 xlt 4 door 4x4
View attachment 434036 View attachment 434037 View attachment 434038
Try radioshack.com, they have a on-line store
Mbrooks420
High Voltage.
1998 Mountaineer AWD
Mbrooks420
High Voltage.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Might be asking a little much but the mounting stud would ease installation.
Mbrooks420
High Voltage.
Mbrooks420
High Voltage.
Hang on….
Mbrooks420
High Voltage.
Mbrooks420
High Voltage.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
What do you mean not ideal? I can handle the wiring / blade connectors.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Makes sense. The way it acted I'm hoping it's the start capacitor. I can almost get it to work spinning it up by hand. It will spin up with nothing on it but the motor has a buzz/feedback type noise to it.
Mbrooks420
High Voltage.
Usually the starting capacitor provides a phase angle difference that determines rotation. Typically you can live without a start capacitor, but you need to get it to spin manually.
The not ideal part of the capacitor I posted was not having the blade connectors. Electrically, it would function.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Honestly I think the start capacitor has been giving me signs. Intermittently I felt the need to help it spin up as it as it wouldn't spin up as fast as normal. The 10uf cap is the only one I can't find with blade terminals and stud mount. Figure I'll zip tie it to the other one to at least get it working.
donalds
Location
Stem
Nc
1999 ford explorer sohc
This is where I always get my stuff from
If you can't find it you ain't looking
Use the search bar type in capacitors and then pick from the list
Mbrooks420
High Voltage.
I think DigiKey is more likely to have board level components. I don’t know how much heavy industrial they stock.
What’s the incoming voltage on this?
