Need help identifying Engine Parts | Ford Explorer - Ford Ranger Forums - Serious Explorations
WacoSportTrac
Waco
2002 Explorer Sport Trac
I need help identifying two electrical connections on my Ford Explorer Sport Trac engine please.
- The first image shows the location on the engine that the two plugs sit.
- The second photo shows the first plug, which is located just behind the oil cap.
- the third photo shows the second plug which is located toward the back of the engine compartment, in front of the passenger seat.
Thanks!
koda2000
x
third photo - I believe that would be the connector to the A/C low pressure switch. The red wiring is not factory.
IDK about the second photo.
david4451
cotabato philippines
2001 ford sport trac
Second photo shows knock sensor connection, it goes to centre of engine block under inlet manifold. Again red wires are non original
