Need help identifying two parts = see pics | Ford Explorer - Ford Ranger Forums - Serious Explorations
08EddieCA
Location
CA
Los Angeles, CA
08 & 03 X (Eddie B & XLS)
I'm trying to identify the oily part located behind the oil filler stem. I'm also trying to identify the metal pipe that runs behind the alternator that connects to a rubber hose. Where it connects to the rubber hose, it's really rusted and dripping coolant.
08EddieCA
Location
CA
Los Angeles, CA
By the way, it's a v6 4.0 (2008). 130k on odo. I'm about to replace the water pump so I want to take care of these two items while I'm in there.
I think the top item is a type of pcv. The bottom appears to be a coolant pipe I'm unfamiliar with.
Stick4503
Winder, Georgia
1996 & 2004Explorer 4x4
Bottom one looks to be your heater hose to the fire wall. Other one is crank case to intake air tube. Not sure of name.
08EddieCA
Location
CA
Los Angeles, CA
Do you know if the intake air connector is supposed to look full of oil etc? That heater hose connection is leaking. I think I should replace the pipe and hose.
SixPonies
Mahomet, IL
2017 Ford Explorer Sport
While you're at it, replace the thermostat housing. On the 4.0 V6, they're notorious for cracking, not matter what vehicle (Mustang, Explorer, Ranger, Sport Trac, etc.).
