jdpimp
- December 2, 2024
- ST LOUIS, MO
- 2015 Limited AWD
Hi everyone! I need some clarification that my google-fu has been unable to help. My 2015 Ford Explorer (Limited 3.5L AWD Dual Climate Control), while trying to blow HEAT, it is only blowing heat through the driver's side vents (one in the middle and one near the door). The passenger side remains cold. If I switch to defrost or to floor, I can hear what sounds like vents changing but the air still only comes out through the "face" vents (only driver side hot) even though it sounds like it is trying to blow air through the defrost vents. I understand this is probably a blend door (or vent) actuator most likely but they all look like a pain to replace and I'd hate to do the wrong one. On this forum, I saw a diagram that was not helpful (to me)... Can anyone narrow down which actuator? Is it possible that it is the passenger side actuator only? Will FORScan narrow it down (I am not familiar with it but it seems useful?)?
Additional info that may or may not help: During the summer, the A/C would stop blowing cold on hot days when I was stopped at a light or whatever. If I was driving, the air would get cold again (refrigerant pressure seems within range) Also, recently, sometimes the dash "hisses" like air is being passed through a narrow passage. It seems to occur when the car might switch (automatically) from one set of vents to another. Maybe I have heard some quiet clicking as well.
Thanks in advance!
Thanks in advance!
