ArcKamikaze
- September 15, 2010
- NY
- 1999 XLT V6 SOHC Explorer
Hi, I have a couple of problems with my 99 Ford Explorer 4.0 SOHC, and needed some help or suggestions with trying to figure out what's wrong with it.
First problem is the O/D light coming on after decelerating a couple of times (ex: in a city, frequent stops), feels like the tranny is trying to catch up with the shift when I decelerate and then go to take off (like at a stop light), does the small kick from the rear and the o/d light blinks, during which the truck goes into the limp or safety mode and feels heavy. The problem with all this is that I cant figure out what's specifically wrong with it, I have tried getting the code pulled while the light's on (3 different places), and no codes came up. Some places I've taken it to say to shut off the truck in order to find the code, however whenever I do that, the light goes away and the truck runs fine and normal. At first I thought it was the tranny going bad, but ruled that out, seeing as how the truck runs fine and shifts properly while driving. I checked to see if it shifted properly with the flashing o/d light, and it has, even feels smoother with the o/d light on with the exception of it taking longer to accelerate from a stop. Not entirely sure as to what is causing this problem, or if anyone else has experience the same issue.
Second problem with the truck is that it sounds like a diesel when starting up, like its coming from the timing chains (driver side), and only seems to occur during hot days/weather. (On cold days or mornings, especially during the winter, it just starts right up with no rattle, sounds strong, drives better). The sound does however go away after warm up when it does occur, but still im not entirely sure what's wrong with this either.
Last problem is the 2-3 Shift Flare, not sure if this is tied in with the other two, but the truck's rpms do flare up for a second when shifting from 2-3. Wasn't sure if this was normal or not. If not, any suggestions as to how to fix this would gladly be appreciated.
Overall, I've had this Explorer for a year now (has 144,x.. miles on it), with these same issues occurring, and havent had any serious problems with it, other than the ones stated above. I'm at the point of deciding between whether or not to keep it or sell it. Would love to keep it, but these problems have got me thinking that it might be something serious and expensive, and it would just be cheaper to get another vehicle. Would truly appreciate anyone willing to help me with these issues and finding any solutions.
PS: Only solutions I could think of after doing some research, was to replace solenoid, vehicle speed sensor, and timing chains, but not sure if these would fix these problems or not. Am on a small budget.
