Hi everyone,
I recently replaced all ball joints and front calipers/rotors and master cylinder on my '98 sport. I've been trying to bleed w/ out any luck. pedal still hits the floor. It seems like I have a steady stream coming out of the front calipers but not rears. I thought it was the mater because when pumping the brakes with the truck off it builds pressure, but holding the pedal a little more than normal pressure and the pedal starts to fall to the floor. when I start the the truck it immediately hits the floor. Does this sound like classic hcu issues? If there is air in the hcu would I not be able to get the truck even drivable?
Does anyone know if shops like midas or ntb would be able to bleed the hcu? It's the weekend, dealer is closed and need the truck for Monday :frustrate
Thanks in advance,
Jeff
Thanks in advance,
Jeff
