Stick4503
- December 12, 2011
- Winder, Georgia
- 1996 & 2004Explorer 4x4
2004 Explorer with a 4.0 sohc 4x4 with stock suspension. Engine is completely rebuilt and has 4000 miles on it.
Problem started a few weeks ago. Temp gauge reads just under half most of the time, but when under strain the gauge runs up to around 3/4 or a little higher. Turning heat on will usually quickly lower the heat reading. No coolant leak or loss. No steam or smell of typically overheating but seems as if the engine is hotter than normal. Top radiator hose is very very warm (can only touch for a few seconds) , top of radiator is cool (can leave your hand on the fins for a long time) bottom of radiator is as hot as the top hose, bottom radiator hose is warm as well.
Thermostat is new, housing is new. Water pump is old but has no visible damage, rust or otherwise messed up fins inside.
Radiator is old, aka not replaced with the engine. Do I have a blocked radiator, bad temp sensor, bad pump, bad fan clutch. I don't want to change them all if they are not needed. Fan can be turned by hand and stops quick when engine is turned off. Or am I looking at a transmission problem. Gas mileage with new engine is still piss poor 13.5 -14 around town, not city. new fuel pump, I know these things don't get great mileage but I was looking for a little better than this with a new engine.
