Fhantazm
- January 31, 2003
- Bristol, Tn
- 91 Navajo LX 4X4
Hello!
I have been on the board for a while and havent posted in forever, it seems but am having a problem that I need an opinon on. Short story is when the truck was purchased the 4x4 didnt work. I put a brand new shift motor in and it worked great UNTIL!!! Last night. I pressed 4x4 it went in fine. I disengaged and attempted to reengage and nothing. I stopped and attempted to listen for the control module "click" when 4x4 is pressed. There is no click. Im thinking the switch is bad, as there were a few times that I had to press 4x4 a couple of times to get it to work. Im going to attempt the self-test after this post. Any other ideas or thoughts? Has anyone else had the switch go bad?? How about the control module!? Im pretty sure its NOT the shift motor, as it is basically new with very little use. Any thoughts or inputs would be great!
EDIT: The computer seems to pass diagnostics(Flashes 5 times and goes out). Im thinking its the switch. Any ideas what pins on the wiring harness I can jump to bypass switch for testing?
