need help | Ford Explorer Forums - Serious Explorations
need help
donzz
winter park fl
93 limited
my '93 explorer with about 10kmiles since rebuild is running like **** seems to be fuel delivery problem .Replaced the relay fuel filter is less than a year old. feels like it is running out of gas if I punch it once it kicks down into passing gear it smothes out I dont think its a transmission problem because it does the same thing idling in park any ideas?
have you checked the plugs and wires?
what is your fuel pressure at the rail?
what is less than a year? 6months, 9 months, 11 months If your tank is dirty you may need to replace it every 4 to 6 months
Is the check engine light on?
dont know how to check pressure
check engine light is not on
filter is 11 12 months old
plugs and wires 5 months old
thanks for the help
the cheapest thing you can try is to go ahead and replace the fuel filter. you really need to check the fuel pressure
just found the thread on how to check fuel pressure, will do that in am maybe pm if I stay up all night reading this site thanks for all your help guys great site
put new tps on rpm fluctuation's have stopped surging seems to have stopped but I dont seem to have the power I had before
did you set the TPS voltage to .95v ? becuase that will make a huge difference in throttle response
