Need input on choice of tires/rims | Ford Explorer - Ford Ranger Forums - Serious Explorations
Well I'm going to be placing an order soon for a new set of tires and rims....What I have is a 99 Sport w/ 2" Body Lift and TT/Shackles. The tire/rim setup I was planning on is:
15x8 Pro Comp Xtreme Alloy
-with-
33x12.50 - Super Swamper TrXus STS All Terrain
I only run my truck on beach sand and maybe a little mudding if any....just wanted to get some input before I drop a grand :p ...
All this will be ordered from 4wheelparts.com
**Also...I have Axle Code 42 which is "42 - 4.10 non-limited slip (Explorer/Mountaineer)" .... how will that handle with 33's?
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
4.10s will be ok with 33s, you will notice a drop in performance but it wont be horrible... you should make sure your wheels have 3.75" backspacing, that is the most common sized backspacing for explorer enthusiasts... be prepared to do a little trimming in some areas as a 12.5 is a good sized tire....
toop
bullhead city, arizona
'99 ex sport
Would you say just a little trimming on the inner fender and maybe bumper? .... nothing to do do with actual metal?
SplashMan
Cedar Rapids, IA
'93 Ranger
With just the 2" BL, you are going to have to cut on both the front bumper and the bottom of the front wheelwells. I had to take about 1/4" off my wheel wells and a little off the front bumper behind the driving lights, with the TT/3"BL and 33x12.5/15s on 15x8 rims.
toop
'99 ex sport
Can I get some more opinions from any others?....Also SplashMan, would you say go thru the trouble with the trimming and all, or should I just look for some 32x11.50? .... Would 32x12.50 also give me less trimming? .... thanks (need answers quick....planning on ordering tires today)
SplashMan
Cedar Rapids, IA
'93 Ranger
Really it is up to you. I cut because I needed the 33s to wheel with, but if I was just lifting mainly for looks, I'd go with a 32x11.5/15 size. I run 32x11.5/15s now with the 3" BL and they look small, but if it was just a 2" BL they would look nice. With the 32s and the 2" BL you probably won't have to cut.
toop
'99 ex sport
Hmm...Well problem with 32x11.5 is that I cant find one that I like with a good price heh.....was it minor trimming with the 3" BL and 33s?
SplashMan
Cedar Rapids, IA
'93 Ranger
There are a lot of tires in a 32/15, what style are you looking at? A M/T or and A/T? I saw you were looking at the Swamper line, the TSL Radial comes in a 32x10.5/15. SSRs come in a 32x11.5/15. Both good tires for everyday driving with some offroad stuff thrown in.
toop
'99 ex sport
Yeah I saw those as well, but was looking for something around $150..... Looking into the BFG Muds or might suck it up and go with the SSRs ..... for some reason the looks of the Muds dont attract me as much as the Swampers do....
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
if you are looking at bfgs or swampers they also come in some oddball sizes.... i know bfgs make a 33x10.5 and those probably wouldnt need much trimming at all
davidmmm69
Location
Fall river ma
2010 Ford Explorer V6 Fall River Ma...
2002 Mercury Mountaineer
also depends on your vehicle.. because for instance on my 1995. i am running 31's but had 33's on for a day borrowed a buddies to see how they would fit...
rubbed very little and I only have torsian bars adjusted and shackels in the rear...
I was going to do spindals and dd a leafs in rear but too mcuh for the spindals and I decide to go with a body lift. and with my vehicle torsian bars twisted up shackles and a body lift I will be putting at least 33's possible35's more than likely 35's
so basically each vehicle is a little bit differnt...
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
how were you going t odo spindles?
davidmmm69
Location
Fall river ma
95 2wd of course i could add lift spindals.
davidmmm69
Location
Fall river ma
davidmmm69
2002 XLT Explorer 4WD
Fall River Mass also 1995 2wd 4dr explorer
93liftedXLT
left coast
92 xlt
THIS IS THE SAME RIM YOU HAVEW POSTED, BUT I FOUND IT FOR A CHEAPER PRICE
XTREME ALLOY 1869 for only $82.99
The Clock Is Ticking - Only 7 Left!!
XTREME ALLOY 1869
View Larger Image
Your Price:
$82.99
MSRP:
$149.99
You Save:
$67.00
XTREME ALLOY 1869
15X8 = SIZE
5-4.75" = BOLT PATTERN
3-5/8 = BACK SPACING
~ ~XTERME ALLOY AT LOWEST PRICE EVER ~ ~
Bolt Pattern Guide
Part Number: XAW1869-5834
Manufacturer: XTREME ALLOY
toop
'99 ex sport
Mine is the 1079 series...with beadlocks....and bolt pattern is 4.5 for explorers i think....but thanks anyways
93liftedXLT
left coast
92 xlt
this rim, comes in difforent patterns. your kinda real cut and dry man....
toop
'99 ex sport
Still different rims...but yeah didn't think about how they have different bolt patterns lol sorry.....what you mean "cut and dry" lol?
but yeah anyways, thanks for the help....ended up with ..
Xtreme Alloy "Beadlocks" w/ Swamper SSR 32x11.50 ....
