Need pinion torque specs. | Ford Explorer - Ford Ranger Forums - Serious Explorations
sched44
Hollowville, New York
'95 XLT
I would appreciate the following information for my '95 Xplorer XLT from anyone who has it:
For Dana 35 front axle:
-bearing preload in in. lbs. for used bearings
-pinion nut torque in ft. lbs.
For 8.8 traction-lok rear:
Thanks in advance.
madmike
Yuma, AZ
'92 xlt, 93 SAS xlt
i need the same but for a 92:confused: :confused: :confused:
SteveVB
Gaithersburg, Maryland
04 Rubicon w/stuff
from my 91 FSM
8.8
preload- used 8-14 inch-lb ( new 17-27 in/lbs)
pinion torque 160 Ft/lb- note if pinion bearing preload exceeds specification before this torque is obtained, install new spacer.
Dana 35
Pinion preload 15-25 in/lbs
Pinion nut- 200-350 ft lbs
Have fun
madmike
Yuma, AZ
'92 xlt, 93 SAS xlt
thanks dude,
sched44
'95 XLT
Thanks for the info. You've been very helpful. Helm has been out of this manual for quite a while now. I'm using the factory manuals for my '92 F-150 where they can help.
There's something different about the preload spec for an 8.8 traction-lok (limited slip) as opposed to a standard 8.8 diferential, isn't there?
The axle is in the vehicle and this is a post pinion seal replacement.
SteveVB
04 Rubicon w/stuff
Funny thing is yes... the preload on a open with new bearings is 16-29inch/lbs vs the 17-27 inch/lbs with the Trac-Lok. Not sure why, the ranges overlap but they are different values for each axle. Curious. The values for used bearings are the same.
Also from the same chart
: trak-lok, Minimun rotating torque required during bench check after assembly, or in vehicle with one wheel on the ground for original clutch pack - 20 Ft/LBS
Good Luck
sched44
'95 XLT
Thanks much SteveVB. I appreciate the info. and the education.
John S. (sched44)
Msupertek
Axle Annihilator!
Arlington, Texas
1992 4x4 Explorer
Ford Certified Technician
Take it from me I have been working for ford for a long time. Set the pinion preload on the 8.8 at 14 inch pounds if you have used bearings only. If you put new bearings set it at 26 inch lbs. back lash on your ring and pinion gear should be .008 in to .015 in. I prefer
setting it at .012 in. Now for the dana pinion preload should be 17 with used bearings or 26 inch lbs with new bearings and the ring & pinion gear backlash should be .005 to .008 inches. This is brought to you by me you friendly ford certified technician of Texas.:cool:
Msupertek
Axle Annihilator!
Arlington, Texas
1992 4x4 Explorer
Just to clear any misunderstanding on checking preload
WHEN CHECKING PRELOAD THE CARRIER SHOULD NOT BE INSTALLED IN THE HOUSING NOR THE AXLES, ONLY THE PINION SO IT MAY FREE WHEEL. USING AN INCH LBS TORQUE WRENCH WITH NEEDLE POINTER TO SEE AMOUNT OF TORQUE BEING APPLIED, PLACE WRENCH AND SOCKET ON NUT AND TURN, HOW MUCH IT TAKES TO KEEP IT CONSTANTLY TURNING IS YOUR PRELOAD.
Your welcome.:frustrate
