Zville02x
- May 4, 2011
- ohio
- 02 xlt
Ok so a little background.2002 explorer 4.0 5r55w. A few months ago i did a motor swap do to broken timing chain ten. About 2 weeks after the trans wouldnt go in gear, so i figured we didnt get the torque in all the way and messed it or the pump up. So i decided to pull it and i replaced the torque, pump, and also found it had a bad O/D band, then put it all back together after flusing cooler and lines and cleaned valvebody and all that. Today after finally getting it all toghter it moves. During my first test drive i noticed the damn o/d light blinking ( already replaced one block) but it did not do it on flat ground, It only did it when i went up a hill, also at the same time the o/d light started blinking i noticed something else, it kinda feels like a miss but not in the motor???? Then i hit the gas and it kinda stopped??? It has got me baffled, so any advice on this would be much much appriciated.
