need some opinions | Ford Explorer - Ford Ranger Forums - Serious Explorations
need some opinions
bustedstuff
Scranton, PA
'98 X 4x4
fixxxer
Aurora, Co.
93 XLT 4X4
Hi and welcome to the forum!
MustangP51
Connecticut
2009 Limited V8
bustedstuff
Scranton, PA
'98 X 4x4
The funny thing is my car was either a police vehicle or construction to begin with because it has all the holes in the roof from the lighting. Which brings me to my next thing where can I find a mountaineer roof rack.
and again I need to know what supplies to use and how to sand it down.
trj360
1999 XLT SOHC
it would look something like this
bustedstuff
Scranton, PA
'98 X 4x4
I have something similar like that done, i don't have teh same rims, i have the 16s but they're painted black with the stock chrome caps, take a look at my registry in my sig.
justin
How did you get that done, did you do it yourself?
97sprt4x4
Jerz
06 Mazda3 GT
Yes, You have to take the rims off. it's easier if you do them all at once, i did it at work, and left my ex up on jackstands for the day, but however you do it is up to you. I sanded mine down, with 220 grit, then 400 grit, cleaned it off and let them dry, then i sprayed down 4 or 5 coats, i used flat black .99 cent spray paint, you can use whatever you want, gloss satin, bed liner. just take your time and make sure you wait the recomended amount of time, otherwise they will chip. i actually borrowed a spare set of rims off a ranger for the day so i could let mine sit overnight, but this would be an easy weekend project.
good luck and post pics when you complete it.
Justin
bustedstuff
Scranton, PA
'98 X 4x4
Sounds easy enough, thanks for your help.
and is it possible to paint them when theyre still on, im assuming no but I thought Id ask.
Paraphoe
Go big or go home
Willow Grove, PA
'97 XLT
My rig also has black rims and chrome center caps. Originally I was going to paint the caps black, but then didn't mind the look at all.
97sprt4x4
Jerz
06 Mazda3 GT
possible, but extremely hard, and so totally not worth the paint running on you. It's just better all around to take them off. if you have the capability to take the tires off that helps too.. other wise just tape them off.
Good luck
1996explorerxlt
Marshfield, MA
00Mounty+96X both V8 AWD
You should probably take them off and paint them. It will make it easier and produce better results. Not to mention you don't want to get paint overspray on your truck or brakes.
You could take down your spare, swap it with one rim and sand/paint one at a time. That way you can do it right the first time and not rush it.
97sprt4x4
Jerz
06 Mazda3 GT
I would have done this, but i painted after i upgraded my tire size, and i have that control trac and it doesn't do very well with different size tires, i have 31's now, and my spare was a 225 70 15!:eek:
