Need suggestions on rattling noise | Ford Explorer - Ford Ranger Forums - Serious Explorations
minjies
Texas
2002 Explorer
I have a 02 Ford explorer that has been making a rattling noise on startup and noise lowers just a little bit after driving for a while. We changed out the rear timing belt tensioner and the front timing belt tensioner, like some forums suggested, but that did not make a difference.
Cubanlorenzo
2003 Ford Explorer XLT
Check heat shields on the CATS. They're known to break loose and rattle. Mine was rattling pretty loud from 2500-3100 rpms
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
I also had a loose heat shield that was rattling. Worth a shot to check it out.
94Eddie
2010 Mountaineer Premier
You might have a rattling torque convertor. Does the noise go away when overdrive engages?
wangbungal
miami fl
ford ranger xl 97
check your belt tensioner, just replaced mine
ronwc
Largo, FL
2008 XLT
cat
Just replaced one of my cats, was doing just as you described. Inside was loose and rattling, would change when warmed up. Now quite and smooth as normal.
