Need to replace dash light | Ford Explorer - Ford Ranger Forums - Serious Explorations
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
No Mounty no more.
I had a dash light burn out between the 50 and 70 on my speedo. Do I just remove the three screws on the top of the instrument cluster and pull it out or is there more involved?
Big E
Albion MI
91 XLT
I think you pull the pannel off infront of the cluster pull out the screws and unplug the wire harness. Give the bad bulb a quater turn and it should come out. I think :)
Eric
Stephen S
Houston, TX
'07 XLT Ironman
It's a little more involved than that. You'll have to take most of the dash apart on the driver's side in order to get to the guage cluster. You'll then have to remove the guage cluster to locate the bulbs behind it. Here is a thread I started a while back whn I had the same trouble. I detailed the dash removal and changing the light bulbs.
Dead Link Removed
Dash removal process with pictures:
Dead Link Removed
Another helpful thread:
Dead Link Removed
Also, it would be a good idea to replace all of the bulbs while you are back there, so another one doesn't decide to go out on you as soon as you finish. Hope this helps.
regulator
Troy, NY
'95 EB..wit da frawg eyez
Yeah I just did the same thing on my X. I followed the directions someone put up to installing indiglo guages. Once you get that far you are home free. There were 22 detailed picks on the thread.
