fordman67
- February 15, 2012
- Ridgecrest Ca
- 94 ford explorer 4x4
hey all this is my first time post. I have a 94 explorer 4x4 4.0 eng.
the trans went out in it so I got one from pick & pull. installed trans and have no reverse most of the time and have to manual shift it from 2nd in to drive to get it to shift. pulled pan and found shift solenoid burned. replace solenoid still the same then replace valve body with new gasket and its still the same. what could be causing this. any help would be appreciated as I am low on funds. :exp:
