Here is the schematic for the obd2 port (data link connector)
As you can see the wires go directly from the obd2 port through 3 connectors only
C146 (firewall bulkhead connector under your brake booster)
C110 (42 pin square) and c175 (the pcm)
You should not have continuity to wires 89 and 90
89 is circuit 355 grey w white throttle position sensor input
90 is 351 brown w white reference voltage
You do have the pcm unplugged for wire checking?
Many of the wires that were cut after your accident carry power, if there was a dead shirt in your previous repairs it can have repercussions in the wiring system, like short out a pcm, blow relays and fuses
Etc which is why we must first test your wiring
Maybe look at previous repair area and make sure all is still good
Circuit 914 at obd connector should only have continuity through the 3
Connectors
Listed and the pcm
Same goes for 915. As you can see they don’t branch off to other locations (except pats module behind pass airbag)
