Negative Battery Cable Bolt Lock?
Punjab
Colorado
'94 Limited
I'm replacing the negative battery cable on my 94 Explorer and, of course, some seemingly insignificant thing is holding me back from finishing the task.
I easily removed the bolt holding the negative ground cable to the block but I cannot get the bolt out of the bracket that clamps around the rest of the harness.
There is a very thin washer holding on to the bolt behind the bracket. It won't thread off the bolt and just spins with it no matter what I try to hold it with.
This is a mediocre picture of what I'm trying to explain:
Does anyone have any idea how to get this washer off the bolt? I've got a nice new negative cable and really don't want to cut and splice them together.
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
If it's the connector type I'm used to, I've always used a small flat head screw driver to bend it.
Others have used a hack saw.
Punjab
Colorado
'94 Limited
I suppose I might be able to get a flat head in there. It's a tight fit though.
Thanks for the reply!
vq5speed
1991 XLT Manual Locks
Stockton,Ca
Looks like its got a Hex shape. Couldn't you try to hold that thin lock nut with a needle nose plier while you unscrew the bolt
Rhaegal94 Negative battery cable/Engine coolant temp sensor connector Stock 1991 - 1994 Explorers 12
J Negative battery cable Stock 1991 - 1994 Explorers 5
K Where does the negative battery cable go on my '93 X? Stock 1991 - 1994 Explorers 9
T Negative battery cable; please spoon feed me Stock 1991 - 1994 Explorers 2
B Negative Battery Cable Length. Stock 1991 - 1994 Explorers 11
9 Negative Battery Cable question Stock 1991 - 1994 Explorers 6
R Horn Blows after reconnecting negative battery terminal Stock 1991 - 1994 Explorers 2
V Negative Camber Stock 1991 - 1994 Explorers 6
M My camber is in the negative. Stock 1991 - 1994 Explorers 4
K Something is draining my battery and it is not the altenator. Stock 1991 - 1994 Explorers 12
kindaclean93 Biggest battery I can fit in a 93 eddie bauer 4.0? Stock 1991 - 1994 Explorers 1
C Level of difficulty: replacing positive battery cable??? Stock 1991 - 1994 Explorers 2
A 94 Sport keeps draining battery Stock 1991 - 1994 Explorers 3
A Weak alternator and or battery? Stock 1991 - 1994 Explorers 10
B Fuel pump on w/out key on; what are the 2 black wires from i/c by battery? Stock 1991 - 1994 Explorers 14
F Battery gauge jumps around when stopped Stock 1991 - 1994 Explorers 2
J Solved Problems with power/battery/alternator. 91 Explorer 4.0L. Stock 1991 - 1994 Explorers 9
K 92 Exploder Sport 4WD wont crank with new battery and starter relay Stock 1991 - 1994 Explorers 9
U Brake leak/ Battery gauge issues? Stock 1991 - 1994 Explorers 14
T battery Stock 1991 - 1994 Explorers 26
M Battery........... Stock 1991 - 1994 Explorers 11
D '94 Explorer Battery Drain -- ABS Stock 1991 - 1994 Explorers 4
R 1994 ford explorer battery light on but voltage meter reads good voltage Stock 1991 - 1994 Explorers 7
M What keeps the battery in place? Stock 1991 - 1994 Explorers 8
D 94 Sport-battery not staying charged Stock 1991 - 1994 Explorers 17
R Battery Light on Stock 1991 - 1994 Explorers 2
S 94 explorer, battery not charging Stock 1991 - 1994 Explorers 4
E Starter motor won't disengage after (+) battery and starter relay replacement Stock 1991 - 1994 Explorers 3
M Battery replacement? Stock 1991 - 1994 Explorers 29
P Alternator not charging battery Stock 1991 - 1994 Explorers 8
C Battery terminal wire? Stock 1991 - 1994 Explorers 2
Explorin'VA Battery cables put on backwards...ugh Stock 1991 - 1994 Explorers 8
A new battery, new alt, no charge! Stock 1991 - 1994 Explorers 11
J No Electrical Power - new battery, batt cables Stock 1991 - 1994 Explorers 10
E dead battery all the time... Stock 1991 - 1994 Explorers 6
D battery gauge Stock 1991 - 1994 Explorers 3
G HELP! CEL and Battery Dying!! Stock 1991 - 1994 Explorers 2
SwaintaN Dual Post Battery, HO Alternator.. Questions.. Stock 1991 - 1994 Explorers 74
D new battery cable question Stock 1991 - 1994 Explorers 3
C alternator not charging battery Stock 1991 - 1994 Explorers 5
9 Don't know what to get... battery related. Stock 1991 - 1994 Explorers 24
J battery draining over night Stock 1991 - 1994 Explorers 3
1 Battery gauge sticks Stock 1991 - 1994 Explorers 7
A Dead battery won't jump after 2 attempts Stock 1991 - 1994 Explorers 3
C low volts, battery light on Stock 1991 - 1994 Explorers 8
B Battery Voltage Issue Stock 1991 - 1994 Explorers 1
B Battery Died, now alternator won't charge new battery Stock 1991 - 1994 Explorers 6
E Alternator VS old battery Stock 1991 - 1994 Explorers 5
K battery gauge all over place at stoplight Stock 1991 - 1994 Explorers 2
K battery needle all over place at stoplight Stock 1991 - 1994 Explorers 4
Similar threads
