Negative Battery Cable Bolt Lock? | Ford Explorer Forums - Serious Explorations
Punjab
Colorado
'94 Limited
I'm replacing the negative battery cable on my 94 Explorer and, of course, some seemingly insignificant thing is holding me back from finishing the task.
I easily removed the bolt holding the negative ground cable to the block but I cannot get the bolt out of the bracket that clamps around the rest of the harness.
There is a very thin washer holding on to the bolt behind the bracket. It won't thread off the bolt and just spins with it no matter what I try to hold it with.
This is a mediocre picture of what I'm trying to explain:
Does anyone have any idea how to get this washer off the bolt? I've got a nice new negative cable and really don't want to cut and splice them together.
If it's the connector type I'm used to, I've always used a small flat head screw driver to bend it.
Others have used a hack saw.
I suppose I might be able to get a flat head in there. It's a tight fit though.
Thanks for the reply!
Looks like its got a Hex shape. Couldn't you try to hold that thin lock nut with a needle nose plier while you unscrew the bolt
