Neutral Safety Switch | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
Ryan1
White Bear Lake, MN
94 XLT
If my neutral safety switch went out. would it not let my truck start when when in park or neutral?
the only way i can start my truck right now is to touch the two terminals together on the starter relay
Ive replaced the ignition switch, starter realy, negative battery cable i dont know what else to do
Ryan
Does it crank? I need more details. I would think that if you bypass the relay and it work....The relay would be at fault.Maybe I am overlooking something..... I dunno.
For some reason I have this urge to do a voltage drop test on your battery cable but I need more info first....
nope, I turn the key, all the accecesories come on and I go to start it and the relay clicks but the starter doesnt engage.
I can pop the hood and touch the two relay post together with a screwdriver and it starts.
Ryan
First off,what is your battery voltage at?
havent checked that what should it be at
Ryan
with no surface charge, it should be at about 13.6 volts
and if it only starts when you jump the terminals, then you need to replace the switch in between those terminals!
What do you mean by surface charge? is that with the engine running or not running?
Jim what switch would that be and where is it located?
If you are talking about the ignition switch on the steering collumn, I have already replaced that
Ryan
He is talking about the "relay" you baypassed with the screwdriver.
I agree. But I tought you said you replaced it already?
Engine off you should have at least 12.6 volts. (battery is 6 2.1v cells linked in series)
oops... 12.6v is what i meant... i dont know whee i came up with 13.6v?
After you charge a battery....Before you test its voltage you turn on the lights or somthing similar to drop the surface charge.......
yes I have replaced the relay. twice actually thinking i might have recieved a bad one. The most recent replacement would be last sunday
Could my battery cause these symptoms (if it is bad that is)
if my battery was bad would it still all me to be jumping the relay like i am already doing?
Also would it be causing my starter to randomly engage while the engine is runnig
Thanks for everything soo far you guys, I have absolutly no clue when it comes to eletrical stuff.
Ryan
A bad battery or bad/corroded connections will cause a no crank condition. Battery voltage is always the first thing checked.
Can you please rephrase this?
If this is the case you would hear a very nasty noise. The one you hear when someone tries to turn on a car that is already running.
Ryan
No problem
Ryan
You would think not.....
lets try this.....the little red wire with light blue stripe that runs to the starter relay (i believe it energizes the relay) how many volts sould that be sending when the key is in the start position.
Ryan
It depends on how you have you meter leads setup in the circuit.
Voltage drop test
tool required- voltmeter
Put your neg lead on the positve terminal of the battery. Put your Positive lead on the power in terminal of your relay or at the end of your battery cable. When you turn the key from on to run you should see all 12.6 volts drop to zero.
Man Jim. After looking at you post count, pics of a rolled explorer in your gallery..... You must either be zack "sohowcome" from www.svtperformance.com or related to him.;) :D
Funny you should mention that I have been a member here longer than over at SVTPerformance.com :D
I8u,
didn't you know you aren't a true explorer enthusiast till you roll one :p
-Zach
Hahaha. Too funny......:D
:D
