For Sale - NEW 3" inlet / 3" outlet Full Boar Straight Thru Muffler | Ford Explorer Forums - Serious Explorations
For Sale NEW 3" inlet / 3" outlet Full Boar Straight Thru Muffler
willzilla
San Antonio, TX
2000 XLT AWD
$35 (local pickup) or $45 shipped to lower 48 states!
Located in Atoka, TN
Jones Full Boar Max Flow Performance Muffler!!!
3" Center Inlet / 3" Offset Outlet
BRAND NEW!
This great stainless-steel muffler (409SS) features a very smooth, mandrel-bent straight-thru core, with no kinks & ripples you find in other brands straight-thru mufflers. This muffler produces a very smooth, deep performance tone that stays mild when you want it to & gets louder when you open up the throttle!
OUTFLOWS equal size Magnaflow mufflers by a considerable margin!
I bought this muffler with intention of using on my remote mount turbo charged truck but my plans have changed and I need a dual in/dual out style muffler instead unfortunately :-/
409SS is high quality metal and will NOT rust through! Some information on 409SS:
"409 is a titanium stabilized ferritic stainless steel which means that it is a steel alloy containing chromium. It contains less nickel and more carbon than 304 stainless steel. Ferritics are best suited for high temperature applications that require corrosion resistance and high strength. The principal use of 409 stainless steel is automotive exhaust systems and most catalytic converter shells are made of 409. More workable and stable than 304, 409 will accept bending and heat cycling better than 304. It resists both atmospheric and exhaust gas corrosion. It is magnetic due to its higher carbon content. Through chemical reaction, it oxidizes to a slight brownish hue which aids in corrosion resistance. While it does not polish well, it offers the advantages of higher strength, lower cost and longer life due to its heat handling qualities."
Feel free to contact me via email with any questions!
Thank you!
** Ignore everything but the muffler in this pic!
