new abs codes need help!!! | Ford Explorer Forums - Serious Explorations
scorpo8972
Mississauga, Ontario
02 Ford Explorer XLT 4x4
Hi, I had the following codes up until last night. U1262 and the both rear wheel speed sensor circuit failure codes. Changed the rear sensor mounted on diff as I have a 3 channel abs system(finally in the 4 years it was on). Erased the code tested the sytem and it worked. However system disabled instelf again and abs light came back on. Two codes that come up now is Right front wheel speed sensor input signal missing and the U1262 Data link fault (SCP). Can anyone tell me what is going on now?
