New Brakes (Ceramic or Regular)
viking37
Staten Island, New York
2002 XLT
My 2002 is just about set to need a new set of pads all arround (30,000 miles). My question is should I install ceramic instead of reg. Bendix pads? Question 2. Rotors are clean and am not getting any pulsing on breaking. Think i can get away without cutting rotors? Thanks all. Ken
jrford
Birmingham, MI
'10 Sport Trac
I have used both. Ceramic do not dust up like other pads, they do feel vague or Soft but not the same feel as metal. Metal I think stop better but then there is the dust problem. I use only Ceramic, cleaner wheels. Rotors - my guess is you should replace them, most rotor can be measured for a Min thickness. Rotors are really 'soft' now a days, and almost always replaced. For high performace, I heard Cross Drilled Rotors with Metal Matrix pads, will stop anything, cost a lot.
viking37
2002 XLT
ceramic or regular brakes
Thanks jrford. Will prob. go with ceramic and rotors if they cant be cut. :thumbsup:
Z 2002 Ford Explorer ABS light comes on and off pulsating brakes Stock 2002 - 2005 Explorers 0
5 Click and grind plus brakes Stock 2002 - 2005 Explorers 2
E No brakes after changing front brake caliper of 2005 ford explorer Stock 2002 - 2005 Explorers 5
F 2003 Explorer squeal with right turns only (sounds like brakes) Stock 2002 - 2005 Explorers 22
J Instrument cluster goes off when brakes are pushed Stock 2002 - 2005 Explorers 2
0 Rear brakes knocking after replacement Stock 2002 - 2005 Explorers 6
T Brakes causing pull Stock 2002 - 2005 Explorers 3
M AC, rear liftgate, and brakes Stock 2002 - 2005 Explorers 6
Mr_Fruffles 04 Explorer XLT 4.0 Various Questions (Brakes/Heating/Etc) Stock 2002 - 2005 Explorers 11
C Brakes issue Stock 2002 - 2005 Explorers 3
M New brakes make clicking/knocking noise Stock 2002 - 2005 Explorers 2
J squishy sound when pressing brakes Stock 2002 - 2005 Explorers 2
C attempted to change brakes for the first time today Stock 2002 - 2005 Explorers 9
S Multifunction Switch (MFS) have anything to do with the brakes lights? Stock 2002 - 2005 Explorers 1
A Both Rear Brakes Dragging Intermittently Stock 2002 - 2005 Explorers 1
P wierd noise after changing rear brakes Stock 2002 - 2005 Explorers 5
R Tackling Suspension R&R and brakes tomorrow Stock 2002 - 2005 Explorers 7
R Tackling Suspension R&R and brakes tomorrow Stock 2002 - 2005 Explorers 0
S Clank while in reverse and brakes applied. Right front caliper "play" Stock 2002 - 2005 Explorers 3
5 2005 Explorer rear brakes Stock 2002 - 2005 Explorers 2
P Pulsating brakes 2003 Explorer Stock 2002 - 2005 Explorers 2
C Brakes 3rd gen xlt awd Stock 2002 - 2005 Explorers 5
U Brakes grinding while driving Stock 2002 - 2005 Explorers 16
T Brakes Stock 2002 - 2005 Explorers 11
D Towing Brakes?? Stock 2002 - 2005 Explorers 54
D Bleeding brakes, air in the brake lines. Stock 2002 - 2005 Explorers 8
B Rear brakes Stock 2002 - 2005 Explorers 6
H Noise At When Applying Brakes Stock 2002 - 2005 Explorers 0
M New rear brakes are burning Stock 2002 - 2005 Explorers 3
E Spongy brakes after bleeding Stock 2002 - 2005 Explorers 2
0 2003 XLT 4x4 V6 Rear Brakes Stock 2002 - 2005 Explorers 1
S Feels like the brakes on in 4wd Stock 2002 - 2005 Explorers 3
T Rear Brakes: A not formal how to Stock 2002 - 2005 Explorers 17
N Front end feels like brakes on Stock 2002 - 2005 Explorers 2
C Only front brakes working Stock 2002 - 2005 Explorers 2
C Brakes. Stock 2002 - 2005 Explorers 2
I BSI replaced, now need to adjust brakes Stock 2002 - 2005 Explorers 5
0 2003 Explorer sport 2 door ( Rear Brakes) Stock 2002 - 2005 Explorers 3
J Brakes grinding when stopping in snow. Stock 2002 - 2005 Explorers 2
N Check list for back brakes this weekend Stock 2002 - 2005 Explorers 3
A Help with brakes Stock 2002 - 2005 Explorers 5
A Rear brakes dragging a bit? Stock 2002 - 2005 Explorers 5
Kazer need new brakes and rotors Stock 2002 - 2005 Explorers 5
7 2002 Explorer: Adjusting emergency brakes. Stock 2002 - 2005 Explorers 6
S Persistent Sticky Brakes Stock 2002 - 2005 Explorers 2
K 2002 Explorer XLT, rear brakes... And more brakes... Stock 2002 - 2005 Explorers 7
C Noisy brakes on a 2004 Explorer XLT Stock 2002 - 2005 Explorers 5
M A discussion on brakes Stock 2002 - 2005 Explorers 4
G Brakes Lights won't turn off 2003 xlt Stock 2002 - 2005 Explorers 4
D Brakes shudder Stock 2002 - 2005 Explorers 6
Similar threads
