CourtneyLynn
Dunkirk, NY
2002 Ford Explorer XLS
Hey Guys!
my name is Courtney and I just purchased my first Ford, a 2002 Explorer XLS 276XXX. I was unfortunately scammed when I bought this vehicle and now we are trying to get the parts and price things to fix it and get it together by next week. So if anyone can help that would be awesome.
Question 1: Everytime I am looking for an engine to price I can't find it. I have an XLS and the 8th letter in the VIN is K. The fuel it uses is gasoline. But when I look for an engine it comes up as 8th letter K Flex fuel......
We have a code reader here at home and the explorer keeps throwing us P0161 and P0156 codes. It does not have a muffler....we are going to get that. Do you think I should just get a new exhaust system for 127$ and find a cheap CAT, the o2 sensor is only 23$.
Sorry for the randomness. It has been quite a long day. Any help you guys can give me would be greatly appreciated.
Sincerely,
Courtney =)
Machine090767
Minnesota
2014 Explorer XLT
This is going to sound mean, but did you not have the vehicle pre checked by your mechanic prior to you buying it?
Also, if you did some research, you'd find that unfortunately, the 2002 model explorer is on the list of the worst vehicle to own, due to thousands of complaints www.carcomplaints.com I truly hope you paid very little for this vehicle.
one thing how were you "scammed"?
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
Welcome to the forum. I think the difference between the vin E and K engines is with the fuel system. What most report doing is getting a vin E engine cause it is cheaper and transfer everything from the K engine. I am curious how did you get scammed?
1998Exp
Seattle WA
98 Limited V8 AWD
Hey Guys!
If it doesn't have a muffler, you should definitely install one; it's illegal to drive without it.
Both of the codes you listed point to the circuit of oxygen sensor 2, bank 2. That's the one downstream from the cat, on the driver side. Quite possibly not the sensor itself, but damaged or disconnected wiring.
S 97 mountianeer v8 5.0 leaking and confused Stock 1995 - 2001 Explorers 2
B Wanting to replace Shocks on 2000 Limited... But confused Stock 1995 - 2001 Explorers 15
M A little confused Stock 1995 - 2001 Explorers 3
T Confused about cylinder head purchase Stock 1995 - 2001 Explorers 20
vroomzoomboom confused about egr valve Stock 1995 - 2001 Explorers 4
K Confused Stock 1995 - 2001 Explorers 1
N confused Stock 1995 - 2001 Explorers 12
D 1996 explorer air bag code 12, blowing fuses, confused Stock 1995 - 2001 Explorers 0
R confused on model of transmission. Stock 1995 - 2001 Explorers 7
P Solved 01 Explorer - CONFUSED...Cylinder 1 Misfire and Lean on Bank 1 Stock 1995 - 2001 Explorers 12
A noise in front end drivers side suspension :confused: Stock 1995 - 2001 Explorers 2
G Confused and Frustrated Stock 1995 - 2001 Explorers 2
L Confused on my fuel pressure Stock 1995 - 2001 Explorers 9
D Confused?? rear axle lube Explorer Sport Stock 1995 - 2001 Explorers 3
C My 4x4 is confused-HELP Stock 1995 - 2001 Explorers 0
B Ok now I'm confused (spark plugs) Stock 1995 - 2001 Explorers 11
S confused! Stock 1995 - 2001 Explorers 2
M Advice from the group I'm So Confused Stock 1995 - 2001 Explorers 6
R Rear End Whining and I'm Confused Stock 1995 - 2001 Explorers 4
S so confused... Stock 1995 - 2001 Explorers 2
D Confused by code reader Stock 1995 - 2001 Explorers 2
T Wrong fuel filter? Confused??? Stock 1995 - 2001 Explorers 1
A confused.... Stock 1995 - 2001 Explorers 2
S Sooo confused! Stock 1995 - 2001 Explorers 22
Brandon96 Confused on Replacing Upper/Lower Intake Gaskets Stock 1995 - 2001 Explorers 5
J 96 Explorer help! confused Stock 1995 - 2001 Explorers 0
N Confused, '96 kazoo noise trans or T case... Stock 1995 - 2001 Explorers 13
P PLEASE HELP (CONFUSED) Whine starts 60-70 mph Stock 1995 - 2001 Explorers 11
B Catalytic Converter: Confused Stock 1995 - 2001 Explorers 8
K Confused on front driveshafts cv or not Stock 1995 - 2001 Explorers 11
K To Aussie X owners...i'm confused 2nd gen! Stock 1995 - 2001 Explorers 1
B Im confused with rear lift Stock 1995 - 2001 Explorers 7
Badspell68 Drive shaft or something else – Really Confused! Stock 1995 - 2001 Explorers 40
studd469 confused about alignment Stock 1995 - 2001 Explorers 0
M Confused Stock 1995 - 2001 Explorers 11
W Confused Stock 1995 - 2001 Explorers 3
J Confused about write-up Stock 1995 - 2001 Explorers 5
D upper right control arm -- p/n and design (confused) Stock 1995 - 2001 Explorers 3
B Confused!!! 96 V8s are AWD or 2WD or either? Stock 1995 - 2001 Explorers 10
L Timing Tensioner? Confused. Stock 1995 - 2001 Explorers 2
Similar threads
