n0c7
- April 3, 2006
- Edmonton, Alberta
- 1993 Ford Explorer XLT
Just redid drum brakes including new pads, new spring kit, new wheel cylinders, new cable guide brackets and had the drums turned. Same work done on both sides. Adjusted as best as I could, took for a test drive and everything appeared to work just great. My sister who drives this primarily is complaining of brake noise, just a little squealing at low speed braking in parking lots. I used cheap pads and I'm ready to tell her it'll just disappear over time as most newer vehicles I've driven do the same thing for the first while. Anything I should double check or any break in procedures I can try to help speed this up? I used disc brake caliper lube for the backing plate where the shoes rest as well as the adjuster and wheel cylinders as it was the closest grease I could find.
