weshag
- August 16, 2015
- 2003 Ford Explorer
P2197 Sensor Signal Stuck Lean - B2 S1
I just started my new engine after a slow and steady installation. Everything is good except for a P2197 and running a little rough. New items that pertain to the drivers side and fuel system.
New O2 sensors
New fuel filter
New plugs
New wires
New injectors
New PCV
New Camshaft sensor
Edit** Adding numbers
Fuel Sys 1 = CL-Fault
Fuel Sys 2 = NA
Calc Load (%) = 50.6
ECT (°F) = 111.2
STFT B1 (%) = -5.5
LTFT B1 (%) = 0.0
STFT B2 (%) = 0.0
LTFT B2 (%) = 0.0
Eng RPM = 888
Veh Speed = 0
Spark Adv. = 11.5
IAT (°F) = 62.6
MAF (lb/min) = 1.3
TPS (%) = 18.0
O2S B1 S1 (V) = .32
STFT B1 S1 (%) = -5.5
O2S B1 S2 (V) = 0.000
STFTB1 S2 (%) = 99.2
O2S B2 S1 (V) = 0.020
STFT B2 S1 (%) = 42.2
O2S B2 S2 (V) = 0.000
STFTB2 S2 (%) = 99.2
I also swapped an old sensor back in on Driver side front but still came back with the same error so I put the new sensor back in.
End Edit
Any thoughts that might guide me to a solution are appreciated.
FYI - Starting the engine and no longer hearing the chronic timing chain rattle is soooo nice.
New O2 sensors
New fuel filter
New plugs
New wires
New injectors
New PCV
New Camshaft sensor
Fuel Sys 2 = NA
ECT (°F) = 111.2
STFT B1 (%) = -5.5
LTFT B1 (%) = 0.0
STFT B2 (%) = 0.0
LTFT B2 (%) = 0.0
Eng RPM = 888
Veh Speed = 0
Spark Adv. = 11.5
IAT (°F) = 62.6
MAF (lb/min) = 1.3
TPS (%) = 18.0
O2S B1 S1 (V) = .32
End Edit
