New Forscan Update Allows Module Programming
613GT500
Ontario, Canada
2016 XC90 T8 R-Design
This is confirmed to work on the f-150 anyone wants to be guinea pig and try this for the explorer:
Remote start: In 726-19-01, change 0047 (disabled) to 0148 (enabled).
Remote start MENU option for a 2013 (per another post elsewhere): In 720-01-02, change EC0A to EF2A
What exactly changes are those enabling?
kuko
2014 Explorer Base
We know it works for the f-150, question is does it works for the explorer?
Lewisra
Howell, mi
2017 explorer limited
I just sold my 2014 with remote start or I'd check to see the settings.
metatr0nX81
Austin, TX
2013 Explorer XLT
I was looking at the F-150 settings spreadsheet to enable Remote Start (mentioned in previous posts) on my 2013 EX XLT and found that the BCM address/values are the same on the EX, however the IPC address has very different values on the EX. Has anyone made any progress enabling Remote Start? I think we're really close.
Thanks to @sheltonfilms for posting the screenshots of his FORScan dump!
Lewisra
Howell, mi
Need to get as built data on an explorer with remote start.
Lewisra
Howell, mi
or you can just try it an let us know what happens
Just suggesting if you check the as built, you'd know what the correct settings are for an explorer. If it'd work somebody, look in the mirror, would need to borrow or buy a key with remote start on it.
metatr0nX81
Austin, TX
2013 Explorer XLT
I used @sheltonfilms VIN (2013 LTD with Remote Start), pulled it's As-Built data and ran it through the As-Built compare tool (http://www.compulsivecode.com/Project_AsBuiltCompare.aspx). The tool is impressive in that it can deduce binary differences between As-Built data based on selected features. Unfortunately, the "perfect bits" that the tool identify are numerous, like way more than I would expect to simply enable a feature like Remote Start. Anyway, here's the result of the comparison: http://pastebin.com/hMQ5gav5
kuko
2014 Explorer Base
I am 99.99% sure that the change to BCM will enable remote start, the change to IPC not sure since this string is different from the f-150s but that may be just because their cluster is different, but there is a good chance this will work, this is required so remote start settings will show one the menu.
sheltonfilms
Hoover, AL
2013 Limited 3.5L
You need to get around 10-15 VINS of each with the option and without. When Jesse (Compulse) and I worked with his program to get Navigation bits that's how we had to do it. Best way is to go on autotrader and just keep grabbing VIN numbers from the list of vehicles.
Logic in his program was simple. Group cars with option, group cars without option. See which bits are the same within each group and then compare those to each group to see which ones are different. More VINs you plug in the better chance of narrowing down the correct bits to change.
metatr0nX81
Austin, TX
2013 Explorer XLT
I'm still doing the bit math on my end but am I correct in assuming (based on F-150 findings) that the only modules needing changes are the IPC and BCM? If I reduce the changes to just those two items, I'm left with the following:
Code:
IPC
720-01-01 bit 24  val 0
720-01-02 bit 4  val 1
720-01-02 bit 26  val 1
720-01-02 bit 39  val 1
720-01-03 bit 0  val 1
720-01-03 bit 1  val 1
720-01-03 bit 2  val 1
720-01-03 bit 3  val 1
720-01-03 bit 4  val 1
BCM
726-07-01 bit 6  val 1
726-07-01 bit 15  val 0
726-15-01 bit 15  val 0
726-17-01 bit 15  val 0
726-18-01 bit 7  val 0
726-19-01 bit 7  val 1
726-43-01 bit 6  val 1
726-46-01 bit 21  val 1
726-46-01 bit 22  val 0
There's definitely overlap with the F-150 changes.
metatr0nX81
Austin, TX
2013 Explorer XLT
Code:
IPC
BCM
And I've been meaning to ask. Can I test these changes on my EX without bricking it? For some reason I'm just terrified to experiment on my own vehicle (that I just bought!)
Lewisra
Howell, mi
As long as you save your original file, FORSCAN will prompt you, you can restore it.
sheltonfilms
Hoover, AL
2013 Limited 3.5L
Plus you can always download your as built data from Motorcraft.com
Lewisra
Howell, mi
Yeah, what he said.
Portland, ME
2013 Police Interceptor
Does Forscan work on the Interceptor Utility?
metal_n
Moscow
2017 Explorer Limited+
Can confirm that from the F-150 spreadsheet, in APIM this works fine on Explorer Limited 2017:
7D0-02-01 xxxx x7xx xxxx GT350 boot screen animation ** Sync 3 only **
7D0-02-01 xxxx x9xx xxxx GT350 boot screen animation ** Sync 3 only **
7D0-02-01 xxxx x5xx xxxx RaptorSVT boot screen animation ** Sync 3 only **
7D0-02-01 xxxx x6xx xxxx Mustang boot screen animation ** Sync 3 only **
7D0-02-01 xxxx x4xx xxxx Licoln Presidential boot screen animation ** Sync 3 only **
7D0-02-01 xxxx x8xx xxxx Vignale boot screen animation ** Sync 3 only **
7D0-02-01 xxxx x5xx xxxx Raptor Ford Performance boot screen animation ** Sync 3 v2.2 **
7D0-02-01 xxxx xCxx xxxx RS Ford Performance boot screen animation ** Sync 3 v2.2 **
7D0-02-01 xxxx xBxx xxxx ST Ford Performance boot screen animation ** Sync 3 v2.2 **
7D0-02-01 xxxx xDxx xxxx GT Ford Performance boot screen animation ** Sync 3 v2.2 **
And also this:
7D0-01-01 AA2A 0503 26DB Heated & Cooled Seats & HSW enabled - home screen & climate screen Sync 3 2.x
metal_n
Moscow
EDIT: It works on my '16 Platinum
For those that can't access DDM or PDM, you need an ELM327 that has a switch for the MS-CAN bus.
I did figure out how to enable concurrent fog/brights. 726-27-01 0100-0100-0157
Can you please explain what means enable concurrent fog/brights?
Thanks
E Forscan Help Stock 2011 - 2019 Ford Explorer Discussion 5
Terryhan05 Looking for help in Hampton Roads with Forscan! Stock 2011 - 2019 Ford Explorer Discussion 2
B FORScan Near Memphis Stock 2011 - 2019 Ford Explorer Discussion 1
V Recent FORScan database Stock 2011 - 2019 Ford Explorer Discussion 59
D Backup Camera guidelines keep falling off after being restored with Forscan Stock 2011 - 2019 Ford Explorer Discussion 0
D Looking for members in Ottawa with FORScan Stock 2011 - 2019 Ford Explorer Discussion 5
D Ingelligent Access Key Programming with ForScan Stock 2011 - 2019 Ford Explorer Discussion 6
M Power steering settings (ForScan) for 2018 Explorer (non-Sport) Stock 2011 - 2019 Ford Explorer Discussion 1
Trader0000 Forscan Compass Code Stock 2011 - 2019 Ford Explorer Discussion 4
S Using Forscan to change Battery_Type Stock 2011 - 2019 Ford Explorer Discussion 32
S 2014 XLT Forscan key programming Stock 2011 - 2019 Ford Explorer Discussion 3
L Explorer 2017 , Dark car model by FORScan Stock 2011 - 2019 Ford Explorer Discussion 25
F FORScan 2017 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 16
P FORScan: Enable Average Speed (& RPM if your IPC supports it) Stock 2011 - 2019 Ford Explorer Discussion 2
U P0430 and FORSCAN Stock 2011 - 2019 Ford Explorer Discussion 4
B Bambi mode for 2014 Explorer Sport - FORscan Stock 2011 - 2019 Ford Explorer Discussion 22
E Remote Start 2011-2015 FORSCAN Stock 2011 - 2019 Ford Explorer Discussion 105
I Ready to try Forscan Stock 2011 - 2019 Ford Explorer Discussion 14
M double honk disable/enable with FORscan Stock 2011 - 2019 Ford Explorer Discussion 102
E Spring like sound after Ford´s toe link recall update Stock 2011 - 2019 Ford Explorer Discussion 4
K Open service action: 19B12, abs update Stock 2011 - 2019 Ford Explorer Discussion 4
P Headlight upgrade-update/review Stock 2011 - 2019 Ford Explorer Discussion 4
B PCM Update? Stock 2011 - 2019 Ford Explorer Discussion 3
I (update) Exhaust Pipe Rusting Stock 2011 - 2019 Ford Explorer Discussion 1
D A6 Maps Update Stock 2011 - 2019 Ford Explorer Discussion 0
G 3 Month Update and Review. Stock 2011 - 2019 Ford Explorer Discussion 17
J UPDATE: Factory "Stop Shipment" on all 4wd Explorers! Stock 2011 - 2019 Ford Explorer Discussion 20
M Lost control of throttle after MFT update. Stock 2011 - 2019 Ford Explorer Discussion 8
R Happy to give this update! Stock 2011 - 2019 Ford Explorer Discussion 9
N 2014 ford list of update and colors Stock 2011 - 2019 Ford Explorer Discussion 12
R Just got letter about sync NEW update Stock 2011 - 2019 Ford Explorer Discussion 18
P 2013 Foird Explorer Update Stock 2011 - 2019 Ford Explorer Discussion 1
V which SD card came with update 3.0.2? Stock 2011 - 2019 Ford Explorer Discussion 9
F My EX is 6months old...a quick update... Stock 2011 - 2019 Ford Explorer Discussion 11
J Is The "Where Am I" Nav. Feature Totally Gone from MFT after Update ? Stock 2011 - 2019 Ford Explorer Discussion 11
M Sync update Stock 2011 - 2019 Ford Explorer Discussion 19
C lost systems check since update. Stock 2011 - 2019 Ford Explorer Discussion 7
R Is there a new MFT update newer than April 5? Stock 2011 - 2019 Ford Explorer Discussion 18
S Vehicle Health Report - after MFT Update Stock 2011 - 2019 Ford Explorer Discussion 15
E My Ford Touch Update Stock 2011 - 2019 Ford Explorer Discussion 12
E Got update at dealer but didn't get the booklets. Stock 2011 - 2019 Ford Explorer Discussion 4
N Great mft update !!! Stock 2011 - 2019 Ford Explorer Discussion 7
T My mini review of the MFT Performance Update Stock 2011 - 2019 Ford Explorer Discussion 9
H Installing update file from edge sport Stock 2011 - 2019 Ford Explorer Discussion 10
P Dealer Installed MFT Update Stock 2011 - 2019 Ford Explorer Discussion 45
B MFT Upgrade/Update Part Numbers Stock 2011 - 2019 Ford Explorer Discussion 7
H MFT Performance update ipod playback MAJOR improvement!! Stock 2011 - 2019 Ford Explorer Discussion 4
S MyFord Touch update rolling out now Stock 2011 - 2019 Ford Explorer Discussion 1
S MFT Software update - you sure it isn't a hardware issue? Stock 2011 - 2019 Ford Explorer Discussion 4
E MFT Update received...well... Stock 2011 - 2019 Ford Explorer Discussion 12
Similar threads
