Well guys I'm 19 & just picked up a 98 expo 2wd 4door. I'm the second owner, has 218k & all major maintenance done. What a buy...Anyway I plan to build a prerunner out of it.
I had a jeep xj previous to this & we built in into a jeepspeed, straight axle prerunner. Did good but I want something that has IFS & the expo is it. Anyway we built the tired 4.0 into a long rod 4.6L stroker. It was a torque monster & had a powerband from 800-4700rpm.
With the build will come 33x12.5's & a full cage front-rear. Truck has 4.10's but I may regear to 4.56's incase I go 35's later! The truck will not be lightweight at all, probably close to 5500+-lbs.
So I was thinking why not stroke it a little, then I saw that some people swapped in a 351. I'm curious about both, what kind of issues will I run into with a 351 swap into a 2wd expo? And if I don't go that route, can someone help me get a build list together for a 331. I plan to run on 87oct either way and am hoping for a powerband of 500-5500rpm! The motors got to keep me going 65-80mph through silt, sand & whoops!
So which would be better, swap a 351 or stroke to 331?
What all is required to swap the 351 into a 2wd expo?
If I choose to do the stroker, can you guys help me put a parts list together that will suit my needs?
Please help out the new guy lol.
